My microwave portion of this works fine but the convection bake part has started making a loud scrubbing noise when I first turn it on. When the oven gets hot the noise stops. The other day the noise did not come and my oven did not heat up. About a year ago I found that the noise was coming from the impeller which had a loose screw. I tighten the screw and noise stopped but now noise is back and the screw is not loose. If the impeller does not make this noise then it will not heat up????? Do I need to replace the unit or can it be repaired and why is it making this noise in the first place?????
Thanks for the advise
