Rank:: Member
When I open the door the turntable rotates and it sounds like the motor or fan is running. I called ge they said the symptom is indicative of the door being out of alignment and it may be leaking microwaves. Can I adjust the door or what is necessary to do to fix this. They suggested I trip the breaker and open and close the door two or three times, (you can't make this stuff up). But that did not help or change the problem. They have no technicians in my area so it is a self help item!
Thanks in advance !
