The door on the oven has two latches, an upper and lower. The lower latch is broken and does not engage the switch inside the chassis. (I am assuming that this is a safety switch. The lights and vent work fine but the oven will not cook.) The problem is that even though the door diagram shows the latches, I can't find them listed as a part. Am I not looking hard enough or am I going to have to spend a lot of money to replace the entire door assembly?
