I have a Sharp R1874F, an over-the-counter microwave in my '07 Motorhome, which came with the RV when new. It is continuing to blow the ceramic fuse, after a very brief time in the cook cycle. A couple years ago both the magnatron and capacitor were re- placed, and all has been working normally. On this occasion my wife was cooking a small roast and pressed Stop to reset and add more time. She pressed Start and it began to cook. After a short time she checked and found the unit was off and would not restart. There was no power. The circuit breaker was found to be o.k. I replaced the ceramic fuse and the unit came on and began cooking again, for a brief time before again blowing the same fuse. Does this sound like something as serious as the magnatron and/or capacitor again? Or, perhaps something probably less serious and costly? Would appreciate any thoughts and advice. Larry
