Discuss
Can a hole in a microwave be patched?
 in
Microwave Repair
I was given a microwave. Upon inspection I saw a big area of rust in the back corner. I bought
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Can a hole in a microwave be patched?
  #1 (permalink)
Old 07-06-2014, 07:49 PM
Junior Member
LaurieAC is on a distinguished road
Exclamation Can a hole in a microwave be patched?
Model Number: 565.61209000   Brand: Kenmore   Age: 5 - 10 years
I was given a microwave. Upon inspection I saw a big area of rust in the back corner. I bought some appliance paint and while painting the rust I discovered there was a hole in the middle of the rust, about 1' long and 1\4' wide. I don't know what it's hiding, but i have seen microwaves (including this one) that have a piece of cardboard screwed (?) to the inside of the microwave. My question is, can I just cover the hole with something or is it a loss?
Related Models
Frigidaire 5650A AIR CONDITIONER
Magic Chef 5651XRA RANGE- D/I STD ELE
Magic Chef 5651XRS RANGE- D/I STD ELE
Magic Chef 5651XRW RANGE- D/I STD ELE
Magic Chef 5651XUA RANGE- D/I STD ELE
Magic Chef 5651XUS RANGE- D/I STD ELE
Magic Chef 5651XUW RANGE- D/I STD ELE
Frigidaire 5658A AIR CONDITIONER
Hoover 566
Frigidaire 5695A AIR CONDITIONER
Frigidaire 57-2707-00-03 Tap(v2) / Electric Range
Frigidaire 57-2707-10-01 Tap(v1) / Microwave and Electric Wall Oven
Frigidaire 57-2707-10-02 Tap(v3) / Microwave and Electric Wall Oven
Frigidaire 57-2707-10-03 Tap(v1) / Electric Range
Frigidaire 57-2709-00-02 Tap(v1) / Wall Oven
Frigidaire 57-2709-00-06 Tap(v1) / Wall Oven
Frigidaire 57-2709-00-07 Tap(v1) / Wall Oven
Frigidaire 57-2709-10-01 Tap(v1) / Wall Oven
Frigidaire 57-2709-10-03 Tap(v1) / Wall Oven
Frigidaire 57-2709-10-04 Tap(v2) / Wall Oven
Frigidaire 57-2709-10-05 Tap(v3) / Wall Oven
Frigidaire 57-2729-00-01 Tap(v1) / Wall Oven
Frigidaire 57-2729-00-02 Tap(v1) / Wall Oven
Frigidaire 57-5709-10-03 Tap(v0) / Wall Oven
Frigidaire 57-6707-00-03 Tap(v4) / Electric Range
Frigidaire 57-6707-10-01 Tap(v2) / Microwave and Electric Wall Oven
Frigidaire 57-6707-10-02 Tap(v4) / Microwave and Electric Wall Oven
Frigidaire 57-6707-10-03 Tap(v3) / Electric Range
Frigidaire 57-6709-00-03 Tap(v1) / Wall Oven
Frigidaire 57-6709-10-01 Tap(v2) / Wall Oven
Admiral 570AH RANGE- F/S STD GAS
Admiral 570AH-K RANGE- F/S STD GAS
Admiral 570AJ RANGE- F/S STD GAS
Admiral 570AJ-K RANGE- F/S STD GAS
Admiral 570WH RANGE- F/S STD GAS
Admiral 570WH-K RANGE- F/S STD GAS
Admiral 570WJ RANGE- F/S STD GAS
Admiral 570WJ-K RANGE- F/S STD GAS
Admiral 571AH RANGE- F/S STD GAS
Admiral 571AHK RANGE- F/S STD GAS
Admiral 571WH RANGE- F/S STD GAS
Admiral 571WHK RANGE- F/S STD GAS
Hoover 574
Hoover 576
General Electric 57731H7WW WASHER
General Electric 57731H8WW WASHER
General Electric 57731H9WW WASHER
General Electric 57751H3WW WASHER
Kenmore 58051300 DEHUMIDIFIER
Kenmore 58051300000 DEHUMIDIFIER
Kenmore 58051450 DEHUMIDIFIER
Kenmore 58051450100 DEHUMIDIFIER
Kenmore 58051650000 DEHUMIDIFIER
Kenmore 58052300200 DEHUMIDIFIER
Kenmore 58052450000 DEHUMIDIFIER
Kenmore 58052450200 DEHUMIDIFIER
Kenmore 58052650 DEHUMIDIFIER
Kenmore 58052650000 DEHUMIDIFIER
Kenmore 58052650100 DEHUMIDIFIER
Kenmore 58053301300 DEHUMIDIFIER
Kenmore 58053509300 DEHUMIDIFIER
Kenmore 58053650200 DEHUMIDIFIER
Kenmore 58053701300 DEHUMIDIER
Kenmore 58054351400 DEHUMIDIFIER
Kenmore 58054351500 DEHUMIDIFIER
Kenmore 58054351700 DEHUMIDIFIER
Kenmore 58054351800 DEHUMIDIFIER
Kenmore 58054351900 DEHUMIDIFIER
Kenmore 58054501400 DEHUMIDIFIER
Kenmore 58054501500 DEHUMIDIFIER
Kenmore 58054501700 DEHUMIDIFIER
Kenmore 58054501800 DEHUMIDIFIER
Kenmore 58054501801 DEHUMIDIFIER
Kenmore 58054701400 DEHUMIDIFIER
Kenmore 58054701500 DEHUMIDIFIER
Kenmore 58054701700 DEHUMIDIFIER
Kenmore 58054701800 DEHUMIDIFIER
Kenmore 58059600890 DEHUMIDIFIER
Kenmore 58066291690 MICROWAVE
Kenmore 58070074000 AIR CONDITIONER
Kenmore 58070122000 AIR CONDITIONER
Kenmore 58070188000 ROOM AIR CONDITIONER
Kenmore 58071056100 AIR CONDITIONER
Kenmore 58071073100 AIR CONDITIONER
Kenmore 58071082100 AIR CONDITIONER
Kenmore 58071121100 AIR CONDITIONER
Kenmore 58071122100 AIR CONDITIONER
Kenmore 58071184100 AIR CONDITIONER
Kenmore 58072053100 AIR CONDITIONER
Kenmore 58072056200 AIR CONDITIONER
Kenmore 58072059200 AIR CONDITIONER
Kenmore 58072066200 AIR CONDITIONER
Kenmore 58072077200 AIR CONDITIONER
Kenmore 58072082200 AIR CONDITIONER
Kenmore 58072083200 AIR CONDITIONER
Kenmore 58072087200 ROOM A/C
Kenmore 58072089200 ROOM A/C
Kenmore 58072093200 AIR CONDITIONER
Kenmore 58072104200 AIR CONDITIONER
Kenmore 58072124200 AIR CONDITIONER
Kenmore 58072124300 AIR CONDITIONER
Kenmore 58072126200 AIR CONDITIONER
Kenmore 58072127200 AIR CONDITIONER
Kenmore 58072128200 AIR CONDITIONER
Kenmore 58072144200 AIR CONDITIONER
Kenmore 58072184200 AIR CONDITIONER
Kenmore 58072187200 AIR CONDITIONER
Kenmore 58072187300 AIR CONDITIONER
Kenmore 58072189200 AIR CONDITIONER
Kenmore 58073053200 AIR CONDITIONER
Kenmore 58073069300 AIR CONDITIONER
Kenmore 58073069301 AIR CONDITIONER
Kenmore 58073082300 AIR CONDITIONER
Kenmore 58073083300 AIR CONDITIONER
Kenmore 58073089300 AIR CONDITIONER
Kenmore 58073093300 AIR CONDITIONER
Kenmore 58073103200 AIR CONDITIONER
Kenmore 58073104300 AIR CONDITIONER
Kenmore 58073123200 AIR CONDITIONER
Kenmore 58073144300 AIR CONDITIONER
  #2 (permalink)
Old 07-07-2014, 06:09 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
The cardboard on the side is to let microwaves into the oven cavity from the magnetron.
The magnetron is also in a sealed housing that is grounded to the oven case.
I would junk the unit.
It could probably be fixed with a piece of metal screwed/bolted over the hole.
either on the inside or outside of the oven case.
The problem is that you have no way to check if this actually stopped the microwaves from leaking out of the oven cavity.
__________________
  #3 (permalink)
Old 07-07-2014, 09:15 AM
Junior Member
Default
If I do decide to cover it, the metal can't stay exposed, right? Do I have to paint it over with the appliance paint?
  #4 (permalink)
Old 07-07-2014, 12:22 PM
Senior Expert
APP Volunteer
Default
It does not matter if it is painted.
The side that contacts the bare metal of the oven cavity should be bare metal so that the plate is grounded to the cavity.
__________________
  #5 (permalink)
Old 07-09-2014, 10:52 AM
Junior Member
Talking
Got it! Thank you so much for your time and help!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dishwasher tub hole romeroom Dishwasher Repair 4 04-27-2011 08:24 PM
Hole burned thru Resin Cover in cavity of microwave dscottjp Microwave Repair 1 02-22-2011 12:52 PM
Hole in accumulator homedoctor Dishwasher Repair 0 11-14-2010 02:33 PM
Is microwave safe with hole in inner door? dpepsi Microwave Repair 0 10-29-2010 02:21 PM
Fire in the hole! boboinmo Microwave Repair 0 10-28-2010 06:33 PM
