The door lock wont engage is selfcleaning mode , so the clean does not work. So to investigate and replace the part... I tried to take off the middle panel at on the top of the oven and below the micro.. I found I thought all the screws but it seems to be attached still ?? any video or schematic?
how much is the part?
Ned
