Discuss
Microwave GE Spacemaker is again cracked
 in
Microwave Repair
I wrote to this site last fall and received accurate and valuable information from Gene. Since then, the microwave is
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Microwave GE Spacemaker is again cracked
  #1 (permalink)
Old 02-15-2008, 10:30 AM
perltech perltech is offline
Junior Member
perltech is on a distinguished road
Default Microwave GE Spacemaker is again cracked
Model Number: JVM1630WB004   Brand: GE   Age: 5 - 10 years
I wrote to this site last fall and received accurate and valuable information from Gene. Since then, the microwave is again cracked and I wrote the following to GE:
Last fall, Oct 2007, I replaced the control panel frame (AP2017933) and the outer door frame (AP2033286) because they were both cracked. I received excellent help from "AppliancePartPros.com" on how to do the re-installation. This past month (Jan 2008) I noticed that the control panel frame is now missing a piece in the same area and the outer door frame is again cracked. The unit is mounted ~ 15.5" above a slide in range Model # JGS968T0H3WW and I believe the excessive heat from the largest burner is causing this. Have you had other complaints of this type ? ? Do you have some sort of heat shield to protect the microwave from the heat emanating from the burner ? ? Do you have any other suggestions ? ?
Thank you for your rapid response to this problem.
David Perlmutter
I am hoping that GE can respond positively to this request, but I thought it important to note 1) the value of Gene's information and directions on how to replace those two parts 2) the possibility of some sort of heat shield or modification to reduce the heat from the burner below.
David Perlmutter
Related Models
General Electric JVM1630WB004 Counter top microwave
General Electric JVM1630WB005 Counter top microwave
General Electric JVM1630WB006 Counter top microwave
General Electric JVM1630WB007 Counter top microwave
General Electric JVM1630WB01 Counter top microwave
General Electric JVM1630WB02 Counter top microwave
General Electric JVM1630WB03 Counter top microwave
General Electric JVM1630WH001 Counter top microwave
General Electric JVM1630WH002 Counter top microwave
General Electric JVM1630WH003 Counter top microwave
General Electric JVM1630WJ01 Counter top microwave
General Electric JVM1630WJ02 Counter top microwave
General Electric JVM1630WJ03 Counter top microwave
General Electric JVM1630WK01 Counter top microwave
General Electric JVM1631BB001 Counter top microwave
General Electric JVM1631BB002 Counter top microwave
General Electric JVM1631BB003 Counter top microwave
General Electric JVM1631BB004 Counter top microwave
General Electric JVM1631BB005 Counter top microwave
General Electric JVM1631BB006 Counter top microwave
General Electric JVM1631BB007 Counter top microwave
General Electric JVM1631BB01 Counter top microwave
General Electric JVM1631BB02 Counter top microwave
General Electric JVM1631BB03 Counter top microwave
General Electric JVM1631BH001 Counter top microwave
General Electric JVM1631BH002 Counter top microwave
General Electric JVM1631BH003 Counter top microwave
General Electric JVM1631BJ01 Counter top microwave
General Electric JVM1631BJ02 Counter top microwave
General Electric JVM1631BJ03 Counter top microwave
General Electric JVM1631BK01 Counter top microwave
General Electric JVM1631CD001 Counter top microwave
General Electric JVM1631CD002 Counter top microwave
General Electric JVM1631CD003 Counter top microwave
General Electric JVM1631CD004 Counter top microwave
General Electric JVM1631CH001 Counter top microwave
General Electric JVM1631CH002 Counter top microwave
General Electric JVM1631CH003 Counter top microwave
General Electric JVM1631CJ01 Counter top microwave
General Electric JVM1631CJ02 Counter top microwave
General Electric JVM1631CJ03 Counter top microwave
General Electric JVM1631CK01 Counter top microwave
General Electric JVM1631WB001 Counter top microwave
General Electric JVM1631WB002 Counter top microwave
General Electric JVM1631WB003 Counter top microwave
General Electric JVM1631WB004 Counter top microwave
General Electric JVM1631WB005 Counter top microwave
General Electric JVM1631WB006 Counter top microwave
General Electric JVM1631WB007 Counter top microwave
General Electric JVM1631WB01 Counter top microwave
General Electric JVM1631WB02 Counter top microwave
General Electric JVM1631WB03 Counter top microwave
General Electric JVM1631WH001 Counter top microwave
General Electric JVM1631WH002 Counter top microwave
General Electric JVM1631WH003 Counter top microwave
General Electric JVM1631WJ01 Counter top microwave
General Electric JVM1631WJ02 Counter top microwave
General Electric JVM1631WJ03 Counter top microwave
General Electric JVM1631WK01 Counter top microwave
General Electric JVM1640AB001 Counter top microwave
General Electric JVM1640AB002 Counter top microwave
General Electric JVM1640AB003 Counter top microwave
General Electric JVM1640AB004 Counter top microwave
General Electric JVM1640AB005 Counter top microwave
General Electric JVM1640AB006 Counter top microwave
General Electric JVM1640AB007 Counter top microwave
General Electric JVM1640AB01 Counter top microwave
General Electric JVM1640AB02 Counter top microwave
General Electric JVM1640AB03 Counter top microwave
General Electric JVM1640AH01 Counter top microwave
General Electric JVM1640AJ01 Counter top microwave
General Electric JVM1640AJ02 Counter top microwave
General Electric JVM1640BB001 Counter top microwave
General Electric JVM1640BB002 Counter top microwave
General Electric JVM1640BB003 Counter top microwave
General Electric JVM1640BB004 Counter top microwave
General Electric JVM1640BB005 Counter top microwave
General Electric JVM1640BB006 Counter top microwave
General Electric JVM1640BB007 Counter top microwave
General Electric JVM1640BB01 Counter top microwave
General Electric JVM1640BB02 Counter top microwave
General Electric JVM1640BB03 Counter top microwave
General Electric JVM1640BH001 Counter top microwave
General Electric JVM1640BJ01 Counter top microwave
General Electric JVM1640BJ02 Counter top microwave
General Electric JVM1640BJ03 Counter top microwave
General Electric JVM1640CH001 Counter top microwave
General Electric JVM1640CJ01 Counter top microwave
General Electric JVM1640CJ02 Counter top microwave
General Electric JVM1640CJ03 Counter top microwave
General Electric JVM1640SJ01 Counter top microwave
General Electric JVM1640SJ02 Counter top microwave
General Electric JVM1640SJ03 Counter top microwave
General Electric JVM1640WB001 Counter top microwave
General Electric JVM1640WB002 Counter top microwave
General Electric JVM1640WB003 Counter top microwave
General Electric JVM1640WB004 Counter top microwave
General Electric JVM1640WB005 Counter top microwave
General Electric JVM1640WB006 Counter top microwave
General Electric JVM1640WB007 Counter top microwave
General Electric JVM1640WB01 Counter top microwave
General Electric JVM1640WB02 Counter top microwave
General Electric JVM1640WB03 Counter top microwave
General Electric JVM1640WH001 Counter top microwave
General Electric JVM1640WJ01 Counter top microwave
General Electric JVM1640WJ02 Counter top microwave
General Electric JVM1640WJ03 Counter top microwave
General Electric JVM1642AB001 Counter top microwave
General Electric JVM1642AB002 Counter top microwave
General Electric JVM1642AB003 Counter top microwave
General Electric JVM1642AB005 Counter top microwave
General Electric JVM1642AB006 Counter top microwave
General Electric JVM1642AB01 Counter top microwave
General Electric JVM1642AB02 Counter top microwave
General Electric JVM1642AB03 Counter top microwave
General Electric JVM1642BB001 Counter top microwave
General Electric JVM1642BB002 Counter top microwave
General Electric JVM1642BB003 Counter top microwave
General Electric JVM1642BB005 Counter top microwave
General Electric JVM1642BB006 Counter top microwave
  #2 (permalink)
Old 11-04-2009, 09:57 PM
elvis2b elvis2b is offline
Junior Member
elvis2b is on a distinguished road
Default GE Spacemaker Door
I am experiencing the same issues with my door cracking. It just below the handle. Is it safe just to replace the outer white door frame? Or should I just replace the entire door assembly?
  #3 (permalink)
Old 11-05-2009, 08:09 AM
Junior Member
Default Microwave door and handle cracked
I checked the specs on the spacing between the burners below and the bottom of the microwave and my installation met the specs. However, the burner directly below the area that continued to crack was the "high power" burner and it was ! ! I finally went to a dealer and asked them about the problem -- no response at all. They did state that the new spacemaker microwaves had larger, more powerful exhaust fans to "possibly" eliminate that problem. I gave in and bought a new microwave (same basic unit, new fan and new cost). It has worked fine for the last year (except for a noisy platter rotation motor)
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
ge profile spacemaker 2.0 sbramm Microwave Repair 4 11-21-2009 10:06 AM
GE Spacemaker XL1800 stopped heating and awful smell perplexed Microwave Repair 19 11-01-2009 10:32 PM
Spacemaker JVM1660SB008: No Heating Loud Humming Noise Doppan Microwave Repair 1 04-10-2008 02:39 AM
GE Spacemaker XL 1400 powers off with clear button rwhitney2469 Microwave Repair 0 01-05-2008 10:06 AM
Oh no, I cracked the glass! fsimon Oven Repair (including Ranges and Cooktops) 4 09-08-2007 12:01 PM
