Discuss
Panasonic oven shuts off NN-SA651S
 in
Microwave Repair
I have a Panasonic NN-SA651S Inverter Microwave Oven and had it about 1 year. When I use it, the oven
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Panasonic oven shuts off NN-SA651S
  #1 (permalink)
Old 04-23-2014, 11:49 AM
Junior Member
ladybridgeport is on a distinguished road
Default Panasonic oven shuts off NN-SA651S
Model Number: NN-SA651S   Brand: -brand-   Age: Less than 1 year
I have a Panasonic NN-SA651S Inverter Microwave Oven and had it about 1 year. When I use it, the oven works, then a relay click sound occurs and the oven fan shuts down, after a few seconds, clicks again and shuts down. After that, if I try to start the oven again, it clicks and does not turn on, but wants to turn on as if its not getting enough voltage then clicks again and shuts down (fan and oven do not operate when this occurs). The outlet is providing proper voltage. If I unplug the oven from the outlet for five minutes and plug it back in, the microwave operates normal for a random period of time, then the same problem occurs. Does a Sensor & Thermistor need replacing or something, if so how can I find the correct one?
Related Models
Maytag NNS207F REF - SXS
Maytag NNS207F2G REF - SXS
Maytag NNS207F2GA REF - SXS
Maytag NNS207F2GH REF - SXS
Maytag NNS207FA REF - SXS
Maytag NNS207FH REF - SXS
Maytag NNS207G REF - SXS
Maytag NNS207GA REF - SXS
Maytag NNS207GH REF - SXS
Maytag NNS207J REF - SXS
Maytag NNS207JA REF - SXS
Maytag NNS207JH REF - SXS
Maytag NNS208F REF - SXS
Maytag NNS208FA REF - SXS
Maytag NNS208G REF - SXS
Maytag NNS208GA REF - SXS
Maytag NNS208GH REF - SXS
Maytag NNS208J REF - SXS
Maytag NNS208JA REF - SXS
Maytag NNS208JH REF - SXS
Maytag NNS227F REF - SXS
Maytag NNS227FA REF - SXS
Maytag NNS227FH REF - SXS
Maytag NNS227G REF - SXS
Maytag NNS227GA REF - SXS
Maytag NNS227GH REF - SXS
Maytag NNS227GZ REF - SXS
Maytag NNS227GZA REF - SXS
Maytag NNS227GZH REF - SXS
Maytag NNS227J REF - SXS
Maytag NNS227JA REF - SXS
Maytag NNS227JH REF - SXS
Maytag NNS228G REF - SXS
Maytag NNS228GA REF - SXS
Maytag NNS228GH REF - SXS
Maytag NNS228J REF - SXS
Maytag NNS228JA REF - SXS
Maytag NNS228JH REF - SXS
Maytag NNS248G REF - SXS
Maytag NNS248GA REF - SXS
Maytag NNS248GH REF - SXS
Maytag NNS248J REF - SXS
Maytag NNS248JA REF - SXS
Maytag NNS248JH REF - SXS
Maytag NNT156DV REF - TOP MOUNT
Maytag NNT156DVA REF - TOP MOUNT
Maytag NNT156DVH REF - TOP MOUNT
Maytag NNT156G REF - TOP MOUNT
Maytag NNT156GA REF - TOP MOUNT
Maytag NNT156GH REF - TOP MOUNT
Maytag NNT156GZ REF - TOP MOUNT
Maytag NNT156GZ3 REF - TOP MOUNT
Maytag NNT156GZ3A REF - TOP MOUNT
Maytag NNT156GZ3H REF - TOP MOUNT
Maytag NNT156GZA REF - TOP MOUNT
Maytag NNT156GZH REF - TOP MOUNT
Maytag NNT156J REF - TOP MOUNT
Maytag NNT156JA REF - TOP MOUNT
Maytag NNT156JH REF - TOP MOUNT
Norge NNT156K REF - TOP MOUNT
Norge NNT156KA REF - TOP MOUNT
Norge NNT156KH REF - TOP MOUNT
  #2 (permalink)
Old 05-03-2014, 11:46 AM
Junior Member
danleywolfe is on a distinguished road
Default Panasonic Microwave NN-SD681S shuts off
I have similar or same problem with my Panasonic NN-SD681S microwave oven was purchased around 15 months ago. We use it only for heating up / reheating and popcorn, nothing exotic. Say I have set to run for 1 min 10 secs to heat up a cup of coffee. It will run for 20-30 sec, start stuttering or stalling like a car stalling out of gas, then shut off. When it shuts off the input settings on time and power are cleared. Important, a little diamond with a vertical line through it appears flashing in the bottom right area of the display, something like this <|>. I called Panasonic technical support and they were totally unhelpful. After describing the situation as said above, he said I had to pay $7.50 for him to talk to me since the unit is out of service warranty (parts are still covered). After describing the little diamond bit I asked him what it meant and he said he was not allowed to tell me. He then told me to set the time for 5 minutes and turn on, which I did. With nothing in the microwave overn. It ran the course but I notice that left hand side / outside panel of the unit upper area was extremely hot, like scalding - I thought it would burn my hand. Common sense says if you operate the microwave oven on high power input for 5 minutes with nothing inside (to absorb the heat) it might get hot. I told him that it was really hot, and asked why we were doing this. He said he was not allowed to tell me. He gave me the name of the local (independent) service company if I had further problems. What crap customer service! Can anyone help.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven clock slowly fades and oven shuts off elroymcoy Oven Repair (including Ranges and Cooktops) 1 07-25-2011 07:41 AM
Oven temps vary then oven shuts off Little Whaler Oven Repair (including Ranges and Cooktops) 9 02-11-2011 12:06 PM
Panasonic microwave oven larryinmaine Microwave Repair 0 07-01-2009 02:29 PM
kitchen aid wall oven shuts off periodically when cooking with the upper oven? eddevlin Oven Repair (including Ranges and Cooktops) 6 03-15-2009 01:55 PM
(Panasonic) stand-alone microwave-oven turns on upon opening door xela Microwave Repair 1 10-03-2008 01:16 PM
