Discuss
Fried wire at interlock switch
 in
Microwave Repair
My microwave stopped working but the lights and control board all worked. After doing some research it looked like I
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Fried wire at interlock switch
  #1 (permalink)
Old 03-26-2014, 08:11 PM
Junior Member
Darrell086 is on a distinguished road
Default Fried wire at interlock switch
Model Number: JMC8130DDS   Brand: Jenn-Air   Age: 5 - 10 years
My microwave stopped working but the lights and control board all worked. After doing some research it looked like I had a bad interlock switch. Gaining access to the switches was actually quite easy. I tested the 3 switches on the right side and they were all good. Went to the left side and noticed that one of the wires to that switch was fried. Insulation was burnt and wire very overheated. I then tested the switch and it was ok.
After finding that all the switches were fine I decided to connect the two wires together as this switch seems to be redundant if even unnecessary. The microwave works just fine.
QUESTIONS: Do I really need to have these wired to the switch or is it okay to bi-pass? If I use the switch, where can I find a new connector to splice onto the existing wire as I am unable (thus far) to extract the old connector from inside the plastic casing? Most importantly, anyone know why this wire would have overheated? This is a low voltage switch and shouldn't have burnt up.
Related Models
Jenn-Air JMC8130DDS MWAVE- CNTRTP / STAND ALONE
Jenn-Air JMC8130DDW MWAVE- CNTRTP / STAND ALONE
Jenn-Air JMC9158AAB MWAVE- CNTRTP / STAND ALONE
Jenn-Air JMC9158AAQ MWAVE- CNTRTP / STAND ALONE
Jenn-Air JMC9158AAS MWAVE- CNTRTP / STAND ALONE
Jenn-Air JMC9158AAW MWAVE- CNTRTP / STAND ALONE
Jenn-Air JMC9158BAB MWAVE- CNTRTP / STAND ALONE
Maytag JMC9158BAB13 COUNTERTOP MICROWAVE 1.5 CU. FT.
Jenn-Air JMC9158BAS MWAVE- CNTRTP / STAND ALONE
Maytag JMC9158BAS13 COUNTERTOP MICROWAVE 1.5 CU. FT.
Jenn-Air JMC9158BAW MWAVE- CNTRTP / STAND ALONE
Maytag JMC9158BAW13 COUNTERTOP MICROWAVE 1.5 CU. FT.
Maytag JMC9158BCB10 COUNTERTOP MICROWAVE 1.5 CU. FT.
Maytag JMC9158BCS10 COUNTERTOP MICROWAVE 1.5 CU. FT.
Maytag JMC9158BCW10 COUNTERTOP MICROWAVE 1.5 CU. FT.
Maytag JMD2124WS0 MICROWAVE DRAWER 1.0 CU. FT.
General Electric JMP26*05 Electric range
General Electric JMP26*06 Electric range
General Electric JMP26*07 Electric range
General Electric JMP26*08 Electric range
General Electric JMP26*D1 Electric range
General Electric JMP26G*01 GE FREE-STANDING / DROP-
General Electric JMP26G*H1 Electric range
General Electric JMP26G*J1 Electric range
General Electric JMP26G*J2 Electric range
General Electric JMP26G*J3 Electric range
General Electric JMP26G*J4 Electric range
General Electric JMP26G*J5 Electric range
General Electric JMP26G0J3 ELECTRIC DROP-IN RANGES
General Electric JMP26GJ4 ELECTRIC BUILT-IN RANGE
General Electric JMP26GJ5 ELECTRIC DROP-IN RANGE
General Electric JMP28BA1AD Electric range
General Electric JMP28BA1WH Electric range
General Electric JMP28BA2AD Electric range
General Electric JMP28BA2WH Electric range
General Electric JMP28BC1AD Electric range
General Electric JMP28BC1WH Electric range
General Electric JMP28BC2WH Electric range
General Electric JMP28BD1CT Electric range
General Electric JMP28BD2CT Electric range
General Electric JMP28BW1AD Electric range
General Electric JMP28BW1WH Electric range
General Electric JMP28BW2AD Electric range
General Electric JMP28BW2WH Electric range
General Electric JMP28GR1AD Electric range
General Electric JMP28GR1WH Electric range
General Electric JMP28GR2AD Electric range
General Electric JMP28GR2WH Electric range
General Electric JMP28GR3AD Electric range
General Electric JMP28GR3WH Electric range
General Electric JMP28GT1AD Electric range
General Electric JMP28GT1WH Electric range
General Electric JMP28GV1AD Electric range
General Electric JMP28GV1WH Electric range
General Electric JMP29GR1BK Electric range
General Electric JMP29GR2BK Electric range
General Electric JMP29GR3BK Electric range
General Electric JMP29GT1BB Electric range
General Electric JMP29GV1BB Electric range
General Electric JMP2SGR3WH ELECTRIC DROP IN RANGE
General Electric JMP31BL1BB Electric range
General Electric JMP31BL2BB ELECTRIC RANGE
General Electric JMP31CL1CC Electric range
General Electric JMP31CL2CC ELECTRIC RANGE
General Electric JMP31WA1WW Electric range
General Electric JMP31WA2WW Electric range
General Electric JMP31WC1WW Electric range
General Electric JMP31WC2WW Electric range
General Electric JMP31WC3WW ELECTRIC RANGE
General Electric JMP31WR1WH Electric range
General Electric JMP31WR2WH Electric range
General Electric JMP31WT1WW Electric range
General Electric JMP31WV1WW Electric range
General Electric JMP31WW1WW Electric range
General Electric JMP32AR1AG Electric range
Maytag JMRH2 JADE MODULAR OPEN BURNER (COOKING GAS)
Maytag JMRH2A JADE MODULAR OPEN BURNER (COOKING GAS)
 JMRH36B COMMERCIAL COOKING
 JMRH36GT COMMERCIAL COOKING
Maytag JMRH4 JADE MODULAR OPEN BURNER (COOKING GAS)
 JMRH48GT COMMERCIAL COOKING
Maytag JMRH4A JADE MODULAR OPEN BURNER (COOKING GAS)
Maytag JMRH6 JADE MODULAR OPEN BURNER (COOKING GAS)
 JMRHE33 COMMERCIAL COOKING
General Electric JMS07*J1 Electric range
General Electric JMS07*J2 Electric range
General Electric JMS07*J3 Electric range
General Electric JMS07*J4 Electric range
General Electric JMS07*J5 Electric range
General Electric JMS070J3 ELECTRIC DROP-IN RANGES
General Electric JMS07G*P1 Electric range
General Electric JMS07J4 ELECTRIC DROP-IN RANGE
General Electric JMS07J5 27" DROP IN ELECTRIC RANGE
General Electric JMS08BA1AD Electric range
General Electric JMS08BA1WH Electric range
General Electric JMS08BA2AD Electric range
General Electric JMS08BA2WH Electric range
General Electric JMS08BD1AD Electric range
General Electric JMS08BD1WH Electric range
General Electric JMS08BD2CT Electric range
General Electric JMS08BD2WH Electric range
General Electric JMS08BD3CT Electric range
General Electric JMS08BD3WH Electric range
General Electric JMS08BW1AD Electric range
General Electric JMS08BW1WH Electric range
General Electric JMS08BW2AD Electric range
General Electric JMS08BW2WH Electric range
General Electric JMS08GR1AD Electric range
General Electric JMS08GR1WH Electric range
General Electric JMS08GR2AD Electric range
General Electric JMS08GR2WH Electric range
General Electric JMS08GT1AD Electric range
General Electric JMS08GT1WH Electric range
General Electric JMS08GV1AD Electric range
General Electric JMS08GV1WH Electric range
General Electric JMS10GR1AD Electric range
General Electric JMS10GR1WH Electric range
General Electric JMS10GR2AD Electric range
General Electric JMS10GR2WH Electric range
General Electric JMS27G*01 GE FREE-STANDING / DROP-
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
interlock door switch zurkster Microwave Repair 0 01-29-2011 05:09 PM
Interlock switch assembly sama.thompson@ky.gov Microwave Repair 0 09-14-2010 09:34 AM
Hotpoint interlock switch whineycrap Dishwasher Repair 0 09-11-2010 11:18 AM
Interlock Switch Burnout dwlynn Microwave Repair 3 03-02-2009 02:36 PM
Is it the door interlock switch? DS@home Dishwasher Repair 0 09-23-2008 09:31 PM
