Discuss
Frigidaire microwave stopped heating
 in
Microwave Repair
My 4 year old over-the-oven microwave stopped microwaving today, but the convection part works. Everything else seems to work fine.
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Frigidaire microwave stopped heating
  #1 (permalink)
Old 03-24-2014, 09:15 PM
Junior Member
darrenwelson is on a distinguished road
Default Frigidaire microwave stopped heating
Model Number: FGMV153   Brand: Frigidaire   Age: 1 - 5 years
Door switches are good.
I get 120VAC at the inlet side of the high voltage transformer. I assume this means the board is good and its a down-stream fault.
CAP:
I have checked the capacitor and it looks good as does the resistor within the cap.
MAG:
I removed and inspected/checked the magnitron which looks like it is fine when I do a continuity check, but looks a little worn and has some signs of rust. Is this normal?
HIGH V XFORMER:
I get ~0.6ohm on the inlet side of the high voltage transformer when everything is disconnected.
DIODE:
I think I checked the diode properly.
Anyone have ideas as to what to do next?
Replace the diode?
Related Models
Frigidaire FGMV153CLBA MICROWAVE OVEN
Frigidaire FGMV153CLWA MICROWAVE OVEN
Frigidaire FGMV154CLFA MICROWAVE OVEN
Frigidaire FGMV173KBA MICROWAVE
Frigidaire FGMV173KBB MICROWAVE
Frigidaire FGMV173KQA MICROWAVE
Frigidaire FGMV173KQB MICROWAVE
Frigidaire FGMV173KWA MICROWAVE
Frigidaire FGMV173KWB MICROWAVE
Frigidaire FGMV174KFA MICROWAVE
Frigidaire FGMV174KFB MICROWAVE
Frigidaire FGMV174KMA MICROWAVE
Frigidaire FGMV174KMB MICROWAVE
Frigidaire FGMV185KBA MICROWAVE/HOOD COMBO
Frigidaire FGMV185KBB MICROWAVE/HOOD COMBO
Frigidaire FGMV185KBC MICROWAVE/HOOD COMBO
Frigidaire FGMV185KFA MICROWAVE/HOOD COMBO
Frigidaire FGMV185KFB MICROWAVE/HOOD COMBO
Frigidaire FGMV185KFC MICROWAVE/HOOD COMBO
Frigidaire FGMV185KWA MICROWAVE/HOOD COMBO
Frigidaire FGMV185KWB MICROWAVE/HOOD COMBO
Frigidaire FGMV185KWC MICROWAVE/HOOD COMBO
Roper FGP210EN0 GAS RANGE
Roper FGP210EN1 GAS RANGE
Roper FGP210EN3 GAS RANGE
Roper FGP210EN4 GAS RANGE
Roper FGP210EN5 GAS RANGE
Roper FGP210EN6 RANGE
Roper FGP210EQ2 GAS RANGE
Roper FGP210EQ3 GAS RANGE
Roper FGP210EQ4 GAS RANGE
Roper FGP210EQ5 RANGE
Roper FGP210EW0 GAS RANGE
Roper FGP210EW1 GAS RANGE
Roper FGP210EW2 GAS RANGE
Roper FGP210EW3 GAS RANGE
Roper FGP210EW4 GAS RANGE
Roper FGP210KN0 RANGE
Roper FGP210KQ0 RANGE
Roper FGP210VW0 GAS RANGE
Roper FGP210VW1 GAS RANGE
Roper FGP210VW2 GAS RANGE
Roper FGP210VW3 GAS RANGE
Roper FGP210VW4 GAS RANGE
Roper FGP210VW5 GAS RANGE
Roper FGP210VW6 GAS RANGE
Roper FGP215EN0 GAS RANGE
Roper FGP215EN1 GAS RANGE
Roper FGP215EN4 GAS RANGE
Roper FGP215EN5 RANGE
Roper FGP215EN6 RANGE
Roper FGP215EQ3 GAS RANGE
Roper FGP215EQ4 GAS RANGE
Roper FGP215EQ5 RANGE
Roper FGP215EQ6 RANGE
Roper FGP215EW0 GAS RANGE
Roper FGP215EW1 GAS RANGE
Roper FGP215EW2 GAS RANGE
Roper FGP215EW4 GAS RANGE
Roper FGP215EW5 RANGE
Roper FGP215EW6 RANGE
Roper FGP215KN0 RANGE
Roper FGP215KQ0 RANGE
Roper FGP215KQ1 20" GAS FREESTANDING RANGE ELECTRONIC IGNITION STANDARD CLEAN OVEN
Roper FGP215VL6 GAS RANGE
Roper FGP215VW0 GAS RANGE
Roper FGP215VW1 GAS RANGE
Roper FGP215VW2 GAS RANGE
Roper FGP215VW3 GAS RANGE
Roper FGP215VW4 GAS RANGE
Roper FGP215VW5 GAS RANGE
Roper FGP215VW6 GAS RANGE
Roper FGP240HQ0 GAS FREESTANDING RANGE
Roper FGP240HQ1 FREE STANDING, GAS
Roper FGP240HQ2 FREE STANDING, GAS
Roper FGP240KQ0 RANGE
Roper FGP245HQ0 GAS RANGE
Roper FGP245HQ1 FREE STANDING, GAS
Roper FGP245HQ2 FREE STANDING, GAS
Roper FGP245KQ0 RANGE
Roper FGP245KQ1 24" GAS FREESTANDING RANGE ELECTRONIC IGNITION STANDARD CLEAN OVEN
Roper FGP300BL0 30" FREESTANDING GAS RANGE
Roper FGP300BL1 30" GAS RANGE / OVEN
Roper FGP300BL2 30" GAS FREESTANDING RANGE PILOT IGNITION STANDARD CLEAN OVEN
Roper FGP300BW0 30" FREESTANDING GAS RANGE
Roper FGP300BW1 30" GAS RANGE / OVEN
Roper FGP300BW2 30" GAS FREESTANDING RANGE PILOT IGNITION STANDARD CLEAN OVEN
Roper FGP300EN0 GAS RANGES AND OVENS
Roper FGP300EN1 GAS RANGES AND OVENS
Roper FGP300EN2 GAS RANGE
Roper FGP300EN3 GAS RANGE
Roper FGP300EW0 GAS RANGES AND OVENS
Roper FGP300EW1 GAS RANGES AND OVENS
Roper FGP300EW2 GAS RANGE
Roper FGP300EW3 GAS RANGE
Roper FGP300HN0 RANGE
Roper FGP300HW0 RANGE
Roper FGP300KN0 RANGE
Roper FGP300KN1 30" GAS FREESTANDING STANDARD CLEAN RANGE PILOT I
Roper FGP300KN2 30" GAS FREESTANDING STANDARD CLEAN RANGE PILOT IGNITION
Roper FGP300KV2 30" GAS FREESTANDING STANDARD CLEAN RANGE PILOT IGNITION
Roper FGP300KW0 RANGE
Roper FGP300KW1 30" GAS FREESTANDING STANDARD CLEAN RANGE PILOT I
Roper FGP300KW2 30" GAS FREESTANDING STANDARD CLEAN RANGE PILOT IGNITION
Roper FGP305BL0 30" FREESTANDING GAS RANGE
Roper FGP305BL1 30" GAS RANGE
Roper FGP305BL2 30" GAS FREESTANDING RANGE ELECTRONIC IGNITION
Roper FGP305BW0 30" FREESTANDING GAS RANGE
Roper FGP305BW1 30" GAS RANGE
Roper FGP305BW2 30" GAS FREESTANDING RANGE ELECTRONIC IGNITION
Roper FGP305EN0 GAS RANGES AND OVENS
Roper FGP305EN1 GAS RANGE
Roper FGP305EN2 GAS RANGE
Roper FGP305EN3 GAS RANGE
Roper FGP305EN4 GAS RANGE
Roper FGP305EW0 GAS RANGES AND OVENS
Roper FGP305EW1 GAS RANGE
Roper FGP305EW2 GAS RANGE
Roper FGP305EW3 GAS RANGE
Roper FGP305EW4 GAS RANGE
  #2 (permalink)
Old 03-29-2014, 02:16 PM
Junior Member
Default
I was able to locate and fix my problem despite not getting any advice from this forum.
For those with a similar 'no more heating' problem, here is what I did to at least isolate the problem:
1) I turned on the microwave and try to heat. I measured for 120 VAC at the front side of the high voltage transformer. Once I got this, I knew my board, relays, door switches were all allowing the microwave to TRY to heat. If you do not, then the problem is likely upstream from the high voltage xformer.
2) I then checked each; CAP, HV XFormer, diode/rectifier, and magnetron
3) check the capacitor
4) Just replace the diode
5) check for continuity of each; magnetron, high voltage xformer and resistor (within the cap).
I ended up getting good continuity for all items I checked, but suspected my magnetron was bad because the others looked GOOD, and it looked sketchy. NO weird noises, burns, or other tells, but it was bad, was replaced, and not hte MW works again.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire Oven Stopped Heating jroller Oven Repair (including Ranges and Cooktops) 0 02-23-2012 04:22 PM
Microwave just stopped heating richardduncan Microwave Repair 3 10-21-2011 03:04 PM
Frigidaire stopped heating bartlebee Microwave Repair 0 11-09-2010 10:50 PM
Microwave stopped heating ceddy Microwave Repair 1 04-14-2009 03:45 PM
Microwave Stopped Heating Chase119 Microwave Repair 7 01-29-2009 03:50 PM
