I heated a cup of water to clean the microwave and the door blew open. Everything works but when you open and close the door it starts on its own. You can tell the heat is not working - just the light, fan and carousel are running. When you set it to heat it will, but wont stop when it is beeping to say end. Help - would this be the door switches or some kind of relay issue?
