AppliancePartsPros.com
Appliance Repair Help
Microwave Repair
GE Spacemaker -- turntable spins, light works, doesn't heat
Hello:
I was looking for some help with troubleshooting our Microwave.
It's a GE Spacemaker that has been good to us all these years until now.
Just last week I noticed that I had put in a bowl of pasta to reheat, for 2-3 minutes, and when it came out it was still cold.
After further inspection, i have discovered that the light will turn on, the control panel / clock / led is still working and that the turntable rotates.
It just doesn't heat. I have also discovered that if I push the door handle really hard in a certain way that it will heat.
Do i need to replace the handle or door assembly or is it something more serious / complex?
Thank you in advance....
Tadd in Austin, TX
Microwave Repair
