iwant2fixit
#1 Posted : Tuesday, December 17, 2013 7:34:48 AM(UTC)
iwant2fixit
When you push the start button it seems to be running fined. But within seconds it sounds as though the motor is running slow. It is heating the food correctly, and the turntable seems to be running properly. Any suggestions.
AntonioStogsdill
#2 Posted : Tuesday, December 17, 2013 8:39:13 PM(UTC)
AntonioStogsdill
The motor might not be able to hold the load. Probably this is the reason why it slows down. You might wanna change the wiring.
The Lost Ways
scottmoore
#3 Posted : Sunday, December 22, 2013 9:11:48 PM(UTC)
scottmoore
Sometimes it happens due to improper electric supply sometime supply is high and sometime low.I thought you should attach a load-balancer for constant electric flow.
visit here for more
GE PT7800SHASS Combination Microwave / Oven - Key Panel SHORTED (Oven Repair (including Ranges and Cooktops))
by RCAppl Today at 7:59:18 AM(UTC)
GE Oven - Microwave/Oven PT7800SH2SSA (Oven Repair (including Ranges and Cooktops))
by Guest 2/13/2024 11:22:12 AM(UTC)
Kenmore Pizza Oven Microwave (Microwave Repair)
by mwjkmail 2/3/2024 5:10:49 PM(UTC)
Kitchenaid (Whirlpool) Microwave door switches (Microwave Repair)
by ForumUser1 1/11/2024 1:11:07 PM(UTC)
Whirlpool Microwave Lower Bulb will not turn on (WMH31017HS08) (Microwave Repair)
by Axtell 1/2/2024 3:49:44 PM(UTC)
Kitchen aid electric wall microwave and oven (Microwave Repair)
by Guest 11/9/2023 8:15:09 AM(UTC)
Frigidaire Microwave PLMVZ169HCA (Microwave Repair)
by Guest 10/25/2023 11:02:01 AM(UTC)
KitcheAid Microwave/Oven Wall Combo KOCE500ESS05 Error Code F6E8 (Microwave Repair)
by tjperlman 10/19/2023 10:07:59 PM(UTC)
Microwave Advantium 120 display blank (Microwave Repair)
by tod.colbert@gmail.com 8/6/2023 9:13:49 AM(UTC)
Litton model 1800 microwave (Microwave Repair)
by Guest 7/14/2023 7:08:12 PM(UTC)
Microwave touchpad (Microwave Repair)
by duguyisheng 7/6/2023 5:12:28 PM(UTC)
Over range Microwave exhaust fan slows (Microwave Repair)
by Mmetzinger 6/3/2023 7:19:23 AM(UTC)
Dim Light on Microwave (Microwave Repair)
by Guest 5/15/2023 8:31:44 AM(UTC)
Kitchenaid kbms1454bbl microwave (Microwave Repair)
by Guest 4/1/2023 10:24:42 AM(UTC)
Microwave Parts Cannot Be Returned and Microwave Still Has The Problem (Microwave Repair)
by atlantic 3/31/2023 12:42:43 PM(UTC)
