Discuss
Jenn-Air thermostat wire connector
 in
Microwave Repair
A technician told us the thermostat needed to be replaced. He didn't have one at the time. I ordered and
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Jenn-Air thermostat wire connector
  #1 (permalink)
Old 11-22-2013, 04:31 PM
Junior Member
cmmx is on a distinguished road
Default Jenn-Air thermostat wire connector
Model Number: JMV8186AAS   Brand: Jenn-Air   Age: 1 - 5 years
A technician told us the thermostat needed to be replaced. He didn't have one at the time. I ordered and replaced the part (#DE47-20059B). I reconnected one lead, but found the other melted. I cut off the connector and found another at Radio Shack.
My question is, the new connector is insulated in a soft plastic. The original was mounted in a hard plastic fitting. Is there a safety issue using the soft insulated connector? Considering that the hard plastic fitting was melted, I don't know if the soft insulated connector might burn faster or somehow offer less protection.
Thank you.
Related Models
Jenn-Air JMV8186AAS MWAVE- MOUNTED OVER RANGE/WO
Maytag JMV8186AAS14 MICROWAVE OVEN/HOOD 1.8 CU. FT.
Maytag JMV8186AAS16 MICROWAVE OVEN/HOOD 1.8 CU. FT.
Jenn-Air JMV8186AAW MWAVE- MOUNTED OVER RANGE/WO
Maytag JMV8186AAW15 MICROWAVE OVEN/HOOD 1.8 CU. FT.
Maytag JMV8186AAW17 MICROWAVE OVEN/HOOD 1.8 CU. FT.
Jenn-Air JMV8196AAB MWAVE- MOUNTED UNDER CABINET
Jenn-Air JMV8196AAQ MWAVE- MOUNTED UNDER CABINET
Jenn-Air JMV8196AAS MWAVE- MOUNTED UNDER CABINET
Jenn-Air JMV8196AAW MWAVE- MOUNTED UNDER CABINET
Jenn-Air JMV8196ACB MWAVE- MOUNTED UNDER CABINET
Jenn-Air JMV8196ACQ MWAVE- MOUNTED UNDER CABINET
Jenn-Air JMV8196ACS MWAVE- MOUNTED UNDER CABINET
Jenn-Air JMV8196ACW MWAVE- MOUNTED UNDER CABINET
Jenn-Air JMV8208AAB MWAVE- MOUNTED OVER RANGE/WO
Jenn-Air JMV8208AAQ MWAVE- MOUNTED OVER RANGE/WO
Jenn-Air JMV8208AAS MWAVE- MOUNTED OVER RANGE/WO
Jenn-Air JMV8208AAW MWAVE- MOUNTED OVER RANGE/WO
Jenn-Air JMV8208ACB MWAVE- MOUNTED OVER RANGE/WO
Jenn-Air JMV8208ACS MWAVE- MOUNTED OVER RANGE/WO
Jenn-Air JMV8208ACW MWAVE- MOUNTED OVER RANGE/WO
Jenn-Air JMV8208BAB MWAVE- MOUNTED OVER RANGE/WO
Maytag JMV8208BAB14 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag JMV8208BAB17 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Jenn-Air JMV8208BAS MWAVE- MOUNTED OVER RANGE/WO
Maytag JMV8208BAS14 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag JMV8208BAS17 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Jenn-Air JMV8208BAW MWAVE- MOUNTED OVER RANGE/WO
Maytag JMV8208BAW15 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag JMV8208BAW18 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Jenn-Air JMV8208BCB MWAVE- MOUNTED OVER RANGE/WO
Maytag JMV8208BCB14 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag JMV8208BCB17 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Maytag JMV8208BCB18 Microwave Oven/Hood 2.0 Cu. Ft.
Jenn-Air JMV8208BCS MWAVE- MOUNTED OVER RANGE/WO
Maytag JMV8208BCS14 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag JMV8208BCS17 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Maytag JMV8208BCS18 Microwave Oven/Hood 2.0 Cu. Ft.
Jenn-Air JMV8208BCW MWAVE- MOUNTED OVER RANGE/WO
Maytag JMV8208BCW15 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag JMV8208BCW18 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Maytag JMV8208BCW19 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag JMV8208DB00 MICROWAVE OVEN/HOOD 2.0 CU. FT.
Maytag JMV8208DP00 MICROWAVE OVEN/HOOD 2.0 CU. FT.
Maytag JMV8208DS00 MICROWAVE OVEN/HOOD 2.0 CU. FT.
Maytag JMV8208DW00 MICROWAVE OVEN/HOOD 2.0 CU. FT.
Jenn-Air JMV8208WB0 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Jenn-Air JMV8208WP0 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Jenn-Air JMV8208WS0 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Jenn-Air JMV8208WW0 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Jenn-Air JMV9169BAB MWAVE- MOUNTED OVER RANGE/WO
Jenn-Air JMV9169BAP MWAVE- MOUNTED OVER RANGE/WO
Jenn-Air JMV9169BAS MWAVE- MOUNTED OVER RANGE/WO
Jenn-Air JMV9169BAW MWAVE- MOUNTED OVER RANGE/WO
Maytag JMV9186WB0 MICROWAVE OVEN/HOOD 1.8 CU. FT.
Maytag JMV9186WP0 MICROWAVE OVEN/HOOD 1.8 CU. FT.
Maytag JMV9186WR0 MICROWAVE OVEN/HOOD 1.8 CU. FT.
Maytag JMV9186WS0 MICROWAVE OVEN/HOOD 1.8 CU. FT.
Maytag JMV9186WW0 MICROWAVE OVEN/HOOD 1.8 CU. FT.
Maytag JMW2327WB00 27" MICROWAVE / WALL OVEN COMBO
Jenn-Air JMW2327WB01 MICROWAVE
Maytag JMW2327WS00 27" MICROWAVE / WALL OVEN COMBO
Jenn-Air JMW2327WS01 MICROWAVE
Maytag JMW2330WB00 30" MICROWAVE / WALL OVEN COMBO
Maytag JMW2330WS00 30" MICROWAVE / WALL OVEN COMBO
Maytag JMW2427WB00 27" MICROWAVE / WALL OVEN COMBO
Jenn-Air JMW2427WB01 27" MICROWAVE / WALL OVEN COMBO
Maytag JMW2427WS00 27" MICROWAVE / WALL OVEN COMBO
Jenn-Air JMW2427WS01 27" MICROWAVE / WALL OVEN COMBO
Maytag JMW2427WW00 27" MICROWAVE / WALL OVEN COMBO
Jenn-Air JMW2427WW01 27" MICROWAVE / WALL OVEN COMBO
Maytag JMW2430WB00 30" MICROWAVE / WALL OVEN COMBO
Maytag JMW2430WP00 30" MICROWAVE / WALL OVEN COMBO
Maytag JMW2430WR00 30" MICROWAVE / WALL OVEN COMBO
Maytag JMW2430WS00 30" MICROWAVE / WALL OVEN COMBO
Maytag JMW2430WW00 30" MICROWAVE / WALL OVEN COMBO
Maytag JMW3430WB00 30" MICROWAVE / WALL OVEN COMBO
Maytag JMW3430WB01 30" MICROWAVE / WALL OVEN COMBO
Maytag JMW3430WP00 30" MICROWAVE / WALL OVEN COMBO
Maytag JMW3430WP01 30" MICROWAVE / WALL OVEN COMBO
Maytag JMW3430WR00 30" MICROWAVE / WALL OVEN COMBO
Maytag JMW3430WR01 30" MICROWAVE / WALL OVEN COMBO
Maytag JMW3430WS00 30" MICROWAVE / WALL OVEN COMBO
Maytag JMW3430WS01 30" MICROWAVE / WALL OVEN COMBO
Jenn-Air JMW8130AAB WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW8130AAW WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW8130DAB WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW8130DAS WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW8130DAW WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW8330DAB WALLOVEN- S/C MWAVE ELE
Maytag JMW8330DAB15 30" BUILT-IN MICROWAVE/ELECTRIC OVEN COMBO SELF-CLEAN
Jenn-Air JMW8330DAS WALLOVEN- S/C MWAVE ELE
Maytag JMW8330DAS16 30" BUILT-IN MICROWAVE/ELECTRIC OVEN COMBO SELF-CLEAN
Jenn-Air JMW8330DAW WALLOVEN- S/C MWAVE ELE
Maytag JMW8330DAW16 30" BUILT-IN MICROWAVE/ELECTRIC OVEN COMBO SELF-CLEAN
Jenn-Air JMW8527AAB WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW8527AAW WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW8527BAB WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW8527BAW WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW8527CAB WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW8527CAS WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW8527CAW WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW8527DAB WALLOVEN- S/C MWAVE ELE
Maytag JMW8527DAB27 27" BUILT-IN ELECTRIC OVEN NON-CONVECTION
Jenn-Air JMW8527DAQ WALLOVEN- S/C MWAVE ELE
Maytag JMW8527DAQ27 27" BUILT-IN ELECTRIC OVEN NON-CONVECTION
Jenn-Air JMW8527DAS WALLOVEN- S/C MWAVE ELE
Maytag JMW8527DAS28 27" BUILT-IN ELECTRIC OVEN NON-CONVECTION
Jenn-Air JMW8527DAW WALLOVEN- S/C MWAVE ELE
Maytag JMW8527DAW27 27" BUILT-IN ELECTRIC OVEN NON-CONVECTION
Jenn-Air JMW8530AAB WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW8530AAW WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW8530BAB WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW8530BAW WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW8530CAB WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW8530CAS WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW8530CAW WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW8530DAB WALLOVEN- S/C MWAVE ELE
Maytag JMW8530DAB28 30" BUILT-IN ELECTRIC COMBO NON-CONVECTION
Jenn-Air JMW8530DAQ WALLOVEN- S/C MWAVE ELE
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bosch Axxiss washer broken wire on motor wire connector plug essorjsmith Washer Repair 2 03-05-2017 02:57 PM
Just need a 50 cent connector, not an entire $100 wire harness. DeanE Dishwasher Repair 0 06-30-2013 11:37 AM
Burnt igniter wire connector PattiG Oven Repair (including Ranges and Cooktops) 0 09-08-2011 04:16 PM
cannot remove solder-less wire connector on TS rock304 Dishwasher Repair 1 06-03-2011 10:17 AM
Wire connector on lint trap-Frigidaire swinbaby Dryer Repair 3 01-23-2011 04:21 AM
