Discuss
GE Microwave still no heat
 in
Microwave Repair
I bought a new Multi meter with capacitor and anode function. After testing I ordered and installed a new transformer.
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » GE Microwave still no heat
  #1 (permalink)
Old 11-07-2013, 10:26 AM
Junior Member
Sawyer 33 is on a distinguished road
Default GE Microwave still no heat
Model Number: SCB2000CBB03   Brand: GE   Age: 5 - 10 years
I bought a new Multi meter with capacitor and anode function. After testing I ordered and installed a new transformer. Still no heat. 120 volts supplied to the transformer when the cycle is started.
The anode tests with battery are:
Battery 9.43V
Voltage thru diode 6.0 volt
Voltage over diode 3.06 volt
Reverse voltage 0.0
After cycling the microwave for two minutes the transformer, capacitor, & anode are cool, the magnetron is slightly warm.
The magnetron I took out showed a short from connections to the shell and continuity between connectors. The new (used) magnetron has no short (open) to body and continuity between connectors.
The troubleshooting diagram on the mini manual says if transformer ok?, check diode, if ok? check magnetron, if the filament contacts are NOT open or contacts are NOT shorted to ground, replace the capacitor.
The capacitor is rated for 1.0 uF, mine tests 1.02 uF. Contacts test open.
Either I got a bad magnetron from the person that said it came out of a working microwave and need to purchase a new one or my test of the capacitor is faulted and I need a new capacitor?
Am I overlooking something?
Related Models
General Electric SCB2000CBB03 Counter top microwave
General Electric SCB2000CCC03 Counter top microwave
General Electric SCB2000CWW03 Counter top microwave
General Electric SCB2000FBB01 Counter top microwave
General Electric SCB2000FBB02 Counter top microwave
General Electric SCB2000FBB03 Counter top microwave
General Electric SCB2000FCC01 Counter top microwave
General Electric SCB2000FCC02 Counter top microwave
General Electric SCB2000FCC03 Counter top microwave
General Electric SCB2000FWW01 Counter top microwave
General Electric SCB2000FWW02 Counter top microwave
General Electric SCB2000FWW03 Counter top microwave
General Electric SCB2001CSS03 Counter top microwave
General Electric SCB2001FSS01 Counter top microwave
General Electric SCB2001FSS02 Counter top microwave
General Electric SCB2001KSS01 Counter top microwave
General Electric SCB2001KSS02 Counter top microwave
General Electric SCBC2000CBB001 SPEEDCOOK/MICROWAVE
General Electric SCBC2000CBB01 Counter top microwave
General Electric SCBC2000CCC001 SPEEDCOOK/MICROWAVE
General Electric SCBC2000CCC01 Counter top microwave
General Electric SCBC2000CWW001 SPEEDCOOK/MICROWAVE
General Electric SCBC2000CWW01 Counter top microwave
General Electric SCBC2001CSS001 SPEEDCOOK/MICROWAVE
General Electric SCBC2001CSS01 Counter top microwave
Amana SCD19H REF - SXS/I&W
Amana SCD19J REF - SXS/I&W
Amana SCD22J REF - SXS/I&W
Amana SCD22NL REF - SXS/I&W
Amana SCD22NW REF - SXS/I&W
Amana SCD22TBL REF - SXS/I&W
Amana SCD22TBW REF - SXS/I&W
Amana SCD23VBL REF - SXS/I&W
Amana SCD23VBW REF - SXS/I&W
Amana SCD23VL REF - SXS/I&W
Amana SCD23VW REF - SXS/I&W
Amana SCD25J REF - SXS/I&W
Amana SCD25JB REF - SXS/I&W
Amana SCD25JP REF - SXS/I&W
Amana SCD25N2L REF - SXS/I&W
Amana SCD25N2W REF - SXS/I&W
Amana SCD25NL REF - SXS/I&W
Amana SCD25NW REF - SXS/I&W
Amana SCD25TBL REF - SXS/I&W
Amana SCD25TBW REF - SXS/I&W
Amana SCD25TL REF - SXS/I&W
Amana SCD25TW REF - SXS/I&W
Thermador SCD272T BUILT-IN ELECTRIC OVEN
Thermador SCD302T BUILT-IN ELECTRIC OVEN
Amana SCDE25J REF - SXS/I&W
Amana SCDT20H REF - SXS/I&W
Amana SCDT22H REF - SXS/I&W
Amana SCDT25H REF - SXS/I&W
Jenn-Air SCE30500B RANGE- S/C S/I ELE
Jenn-Air SCE30500W RANGE- S/C S/I ELE
Jenn-Air SCE30600B RANGE- S/C S/I ELE
Jenn-Air SCE30600BC RANGE- S/C S/I ELE
Jenn-Air SCE30600W RANGE- S/C S/I ELE
Jenn-Air SCE30600WC RANGE- S/C S/I ELE
Jenn-Air SCE4320B RANGE- S/C S/I ELE
Jenn-Air SCE4320W RANGE- S/C S/I ELE
Jenn-Air SCE4340B RANGE- S/C S/I ELE
Jenn-Air SCE4340B-C RANGE- S/C S/I ELE
Jenn-Air SCE4340W RANGE- S/C S/I ELE
Jenn-Air SCE4340W-C RANGE- S/C S/I ELE
Jenn-Air SCE70600B RANGE- S/C S/I ELE
Jenn-Air SCE70600W RANGE- S/C S/I ELE
Whirlpool SCF0710HQ00 CHEST
Whirlpool SCF0710HQ01 CHEST
Whirlpool SCF0710HW00 CHEST FREEZER
Whirlpool SCF0710HW01 CHEST FREEZER
Whirlpool SCF0710HW05 CHEST FREEZER
Whirlpool SCF0710KQ00 CHEST FREEZER
Whirlpool SCF0710KQ01 CHEST FREEZER
Whirlpool SCF0710KQ02 CHEST FREEZER
Whirlpool SCF0710KQ03 CHEST FREEZER
Whirlpool SCF0710KQ04 CHEST FREEZER
Whirlpool SCF1510HW00 CHEST FREEZER
Whirlpool SCF1510HW02 CHEST FREEZER
Whirlpool SCF1510HW05 CHEST FREEZER
Jenn-Air SCG20200A RANGE- S/C S/I GAS
Jenn-Air SCG20200B RANGE- S/C S/I GAS
Jenn-Air SCG20200W RANGE- S/C S/I GAS
Thermador SCM-1 SPEED CONTROL
Maytag SCM10DB12 CONVENT GAS CARTRIDGE
Maytag SCM20DB11 GAS GRILLE CARTRIDGE
Whirlpool SCS3004GN0 30" GAS COOKTOP
Whirlpool SCS3004GN1 GAS COOKTOP
Whirlpool SCS3004GS0 30" GAS COOKTOP
Whirlpool SCS3004GS1 GAS COOKTOP
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Microwave will not heat scottdugan Microwave Repair 3 07-27-2012 03:51 PM
Microwave won't heat cutiger Microwave Repair 0 03-14-2010 03:21 PM
Microwave won't heat roadkingmike Microwave Repair 0 03-12-2010 07:55 AM
Microwave won't heat JetFla Microwave Repair 2 04-16-2009 12:00 PM
Microwave Does Not Heat. jpeterman12 Microwave Repair 2 03-22-2008 07:37 AM
