| » Microwave dont work |
Model Number: MH1150XMB-3 Brand: Whirlpool Age: 1 - 5 years
MY wife was changing the bulb under the unit with the power plugged in. Touched the bulb, which was cool, and tried to un screw it. The bulb came out of its socket and she heard a pop. The pop I assume is the gas releasing from the bulb. I unplugged the unit, replaced the bulb and there is no signs of life on the unit. I checked breaker panel (ok), I replaced fuse in unit (ok), there is power at the outlet, but nothing at all comes on when the unit is plugged in??????
Related Models |
Check the cavity thermostats for continuity (location shown in the Tech sheet). Probably you have to remove the microwave from the cabinet to access them.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL MH1150XMB3 | AppliancePartsPros.com Gene.
__________________
Professional appliance repair in Orange County, California. |
I just had the same thing happen to me on this morning. the model is MH1150XM. However the fan will go on high, the key pad works. When you start the microwave the clock will turn on and count down however the microwave will not work. Is there anything particular that needs to be replaced, can it be reset or what. I hate to have to go by a new one.
Remove the top grill and open the control panel. Check the door switches and how they are engaged when the door is closed.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL MH1150XMB0 | AppliancePartsPros.com Gene.
__________________
| Display Modes | |
| 2 burners and oven dont work | skongolf | Oven Repair (including Ranges and Cooktops) | 9 | 10-10-2009 12:00 AM |
| Dryer wont heat up and timer cycles dont work. | ggordon007 | Dryer Repair | 0 | 08-03-2009 07:47 AM |
| ice and water in door dont work | smithburgbrandon | Refrigerator & Freezer Repair | 0 | 06-23-2009 09:46 AM |
| Washer Arms Dont Work | sarmad57 | Dishwasher Repair | 0 | 08-29-2008 03:08 PM |
| oven dont work and its not the igniter | nothings impossible | Oven Repair (including Ranges and Cooktops) | 0 | 10-30-2007 12:24 PM |
