Discuss
replacing light in microwave oven
 in
Microwave Repair
I need to replace the light in the Microwave oven of this Convection Oven/Microwave stack. I ordered and received the
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » replacing light in microwave oven
  #1 (permalink)
Old 09-23-2013, 05:04 PM
Junior Member
chuckj3456 is on a distinguished road
Default replacing light in microwave oven
Model Number: KEMC378KSS02   Brand: Kitchen Aid   Age: 5 - 10 years
I need to replace the light in the Microwave oven of this Convection Oven/Microwave stack. I ordered and received the bipin 12V 5W halogen light, but the only thing in the oven cavity is a rounded glass tube that seems to be spring loaded, protruding from the top of the oven. Is this the light housing? If so, how do you uscrew or release it to replace the bulb? If not, what do you need to do to replace the bulb, pull the oven from the frame and access it from the top?
ChuckJ3456
Related Models
Whirlpool KEMC378KSS02 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION LOWER MICROWAVE CONVECTION
Whirlpool KEMC378KSS03 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION LOWER MICROWAVE CONVECTION
Whirlpool KEMC378KSS04 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION LOWER MICROWAVE CONVECTION
Whirlpool KEMC378KWH0 OVEN WITH MICROWAVE
Whirlpool KEMC378KWH01 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION LOWER MICROWAVE CONVECTION
Whirlpool KEMC378KWH02 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION LOWER MICROWAVE CONVECTION
Whirlpool KEMC378KWH03 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION LOWER MICROWAVE CONVECTION
Whirlpool KEMC378KWH04 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION LOWER MICROWAVE CONVECTION
Whirlpool KEMI300SBL0 BUILT-IN OVEN WITH MICROWAVE
Whirlpool KEMI300SBL1 BUILT-IN OVEN WITH MICROWAVE
Whirlpool KEMI300VBL0 BUILT-IN OVEN WITH MICROWAVE
Whirlpool KEMI300VBL1 BUILT-IN OVEN WITH MICROWAVE
Whirlpool KEMI300VBL2 BUILT-IN OVEN WITH MICROWAVE
Whirlpool KEMI300VBL3 BUILT-IN OVEN WITH MICROWAVE
Whirlpool KEMI300VBL4 BUILT-IN OVEN WITH MICROWAVE
Whirlpool KEMI300VBL5 BUILT-IN OVEN WITH MICROWAVE
KitchenAid KEMI300WBL0 ELEC. BUILT-IN OVEN / MICROWAVE OVEN
Whirlpool KEMI300WBL1 ELEC BUILT-IN OVEN / MICROWAVE OVEN
Whirlpool KEMI300WBL2 ELEC BUILT IN OVEN / MICROWAVE OVEN
Whirlpool KEMI300WBL3 30" BUILT-IN COMBINATION OVEN
Whirlpool KEMI301BWH0 30" ELECTRIC BUILT-IN OVEN WITH MICROWAVE
Whirlpool KEMI301GBL0 30" BUILT-IN ELECTRIC OVEN
Whirlpool KEMI301GWH0 30" BUILT-IN ELECTRIC OVEN
Whirlpool KEMI371BBL0 27" BUILT-IN OVEN W/MICROWAVE
Whirlpool KEMI371BBL1 27" BUILT-IN OVEN
Whirlpool KEMI371BBL2 27" BUILT-IN OVEN
Whirlpool KEMI371BWH0 27" BUILT-IN OVEN W/MICROWAVE
Whirlpool KEMI371BWH1 27" BUILT-IN OVEN
Whirlpool KEMI371BWH2 27" BUILT-IN OVEN
Whirlpool KEMI371GBL0 27" BUILT-IN ELECTRIC WALL OVEN
Whirlpool KEMI371GWH0 27" BUILT-IN ELECTRIC WALL OVEN
Whirlpool KEMI371SBL0 Ranges, Electric*
Whirlpool KEMI371TBL0 Ranges, Electric*
Whirlpool KEMI371TBL1 ELECTRIC RANGE
Whirlpool KEMI371TBL2 ELECTRIC RANGE
Whirlpool KEMI371TBL3 Ranges, Electric*
Whirlpool KEMI371XBL0 Ranges, Electric*
Whirlpool KEMI371XBL1 Ranges, Electric*
Whirlpool KEMI371XBL2 Ranges, Electric*
Whirlpool KEMI371YWH0 Ranges, Electric*
Whirlpool KEMS306BAL0 BUILT IN OVEN & MICROWAVE OVEN
Whirlpool KEMS306BAL1 BUILT-IN OVEN/MICROWAVE
Whirlpool KEMS306BAL2 BUILT-IN-OVEN/MICROWAVE
Whirlpool KEMS306BAL3 BUILT-IN-OVEN/MICROWAVE
Whirlpool KEMS306BBL0 BUILT IN OVEN & MICROWAVE OVEN
Whirlpool KEMS306BBL1 BUILT-IN OVEN/MICROWAVE
Whirlpool KEMS306BBL2 BUILT-IN-OVEN/MICROWAVE
Whirlpool KEMS306BBL3 BUILT-IN-OVEN/MICROWAVE
Whirlpool KEMS306BWH0 BUILT IN OVEN & MICROWAVE OVEN
Whirlpool KEMS306BWH1 BUILT-IN OVEN/MICROWAVE
Whirlpool KEMS306BWH2 BUILT-IN-OVEN/MICROWAVE
Whirlpool KEMS306BWH3 BUILT-IN-OVEN/MICROWAVE
Whirlpool KEMS306XAL0
Whirlpool KEMS306XAL1
Whirlpool KEMS306XAL3 ELECTRIC WALL OVEN / MICROWAVE COMBINATION
Whirlpool KEMS306XAL4 30" OVEN / CONVECTION MICROWAVE
Whirlpool KEMS306XAL5 30" ELECTRIC BUILT-IN COMBINATION OVEN
Whirlpool KEMS306XAL6 30" SELF-CLEAN OVEN WITH CONVECTION MICROWAVE
Whirlpool KEMS306XBL0 ELEC BUILT-IN OVEN / MICROWAVE OVEN
Whirlpool KEMS306XBL1 ELEC BUILT-IN OVEN / MICROWAVE OVEN
Whirlpool KEMS306XBL2 ELECTRIC BUILT-IN COMBINATION OVEN
Whirlpool KEMS306XBL3 ELECTRIC WALL OVEN / MICROWAVE COMBINATION
Whirlpool KEMS306XBL4 30" OVEN / CONVECTION MICROWAVE
Whirlpool KEMS306XBL5 30" ELECTRIC BUILT-IN COMBINATION OVEN
Whirlpool KEMS306XBL6 30" SELF-CLEAN OVEN WITH CONVECTION MICROWAVE
Whirlpool KEMS306XWH0 Ranges, Electric*
Whirlpool KEMS306XWH1 Ranges, Electric*
Whirlpool KEMS306XWH2 ELECTRIC BUILT-IN COMBINATION OVEN
Whirlpool KEMS306XWH3 ELECTRIC WALL OVEN / MICROWAVE COMBINATION
Whirlpool KEMS306XWH4 30" OVEN / CONVECTION MICROWAVE
Whirlpool KEMS306XWH5 30" ELECTRIC BUILT-IN COMBINATION OVEN
Whirlpool KEMS306XWH6 30" SELF-CLEAN OVEN WITH CONVECTION MICROWAVE
Whirlpool KEMS307DAL1 30" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool KEMS307DAL2 30" BUILTIN ELECTRIC DOUBLE OVEN
Whirlpool KEMS307DAL4 30" BUILT-IN ELECTRIC OVEN/MW
Whirlpool KEMS307DAL6 BUILT - IN ELECTRIC OVEN
Whirlpool KEMS307DBL1 30" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool KEMS307DBL2 30" BUILTIN ELECTRIC DOUBLE OVEN
Whirlpool KEMS307DBL4 30" BUILT-IN ELECTRIC OVEN/MW
Whirlpool KEMS307DBL6 BUILT - IN ELECTRIC OVEN
Whirlpool KEMS307DBS2 30" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool KEMS307DBS4 30" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool KEMS307DBS6 BUILT - IN ELECTRIC OVEN
Whirlpool KEMS307DBT6 BUILT - IN ELECTRIC OVEN
Whirlpool KEMS307DWH1 30" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool KEMS307DWH2 30" BUILTIN ELECTRIC DOUBLE OVEN
Whirlpool KEMS307DWH4 30" BUILT-IN ELECTRIC OVEN/MW
Whirlpool KEMS307DWH6 BUILT - IN ELECTRIC OVEN
Whirlpool KEMS307GAL0 BUILT-IN ELECTRIC OVEN/MW
Whirlpool KEMS307GAL1 ELECTRIC OVEN/MW COMBO
Whirlpool KEMS307GAL2 30" BUILT IN OVEN/MW
Whirlpool KEMS307GBL0 BUILT-IN ELECTRIC OVEN/MW
Whirlpool KEMS307GBL1 ELECTRIC OVEN/MW COMBO
Whirlpool KEMS307GBL2 30" BUILT IN OVEN/MW
Whirlpool KEMS307GBL3 BUILT-IN OVEN, ELECTRIC
Whirlpool KEMS307GBL4 OVEN/ELECTRIC MICROWAVE
Whirlpool KEMS307GBS0 BUILT-IN ELECTRIC OVEN
Whirlpool KEMS307GBS1 ELECTRIC OVEN/MW COMBO
Whirlpool KEMS307GBS2 30" BUILT IN OVEN/MW
Whirlpool KEMS307GBS3 BUILT-IN OVEN, ELECTRIC
Whirlpool KEMS307GBS4 OVEN/ELECTRIC MICROWAVE
Whirlpool KEMS307GBT0 BUILT-IN ELECTRIC OVEN/MW
Whirlpool KEMS307GBT1 ELECTRIC OVEN/MW COMBO
Whirlpool KEMS307GBT2 30" BUILT IN OVEN/MW
Whirlpool KEMS307GBT3 BUILT-IN OVEN, ELECTRIC
Whirlpool KEMS307GBT4 OVEN/ELECTRIC MICROWAVE
Whirlpool KEMS307GWH0 BUILT-IN ELECTRIC OVEN/MW
Whirlpool KEMS307GWH1 ELECTRIC OVEN/MW COMBO
Whirlpool KEMS307GWH2 30" BUILT IN OVEN/MW
Whirlpool KEMS307GWH3 BUILT-IN OVEN, ELECTRIC
Whirlpool KEMS307GWH4 OVEN/ELECTRIC MICROWAVE
Whirlpool KEMS308GBL0 BUILT-IN ELECTRIC OVEN/MW
Whirlpool KEMS308GBL1 ELECTRIC OVEN/MW COMBO
Whirlpool KEMS308GBL2 OVEN/MW
Whirlpool KEMS308GBL3 BUILT-IN OVEN, ELECTRIC
Whirlpool KEMS308GSS0 BUILT-IN ELECTRIC OVEN/MW
Whirlpool KEMS308GSS1 OVEN/MW
Whirlpool KEMS308GSS2 BUILT-IN OVEN, ELECTRIC W/MICROWAVE
Whirlpool KEMS308GSS3 BUILT-IN OVEN/MW, ELECTRIC
Whirlpool KEMS308GWH0 BUILT-IN ELECTRIC OVEN/MW
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Replacing GMC305PDB5 microwave light bulb jcp2013 Microwave Repair 5 03-21-2013 05:31 PM
Replacing microwave oven light bulb wayne-man Microwave Repair 0 03-06-2012 07:45 PM
Replacing Microwave light ahorne1 Microwave Repair 0 02-12-2011 05:58 PM
Replacing A Whirlpool Gold Microwave Light Bulb ish2008 Oven Repair (including Ranges and Cooktops) 1 12-07-2010 05:39 AM
2006 kenmore microwave light bulb needs replacing rogerskoler Microwave Repair 3 01-02-2010 12:15 PM
