Discuss
GE Advantium Microwave turns on when door is closed
 in
Microwave Repair
Builtin microwave turns on when the door is simply closed. It gives a low hum and no fans or other
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » GE Advantium Microwave turns on when door is closed
  #1 (permalink)
Old 09-23-2013, 12:57 PM
Junior Member
FredReitberger is on a distinguished road
Default GE Advantium Microwave turns on when door is closed
Model Number: SCB2000FBB   Brand: GE   Age: 1 - 5 years
Builtin microwave turns on when the door is simply closed. It gives a low hum and no fans or other indicators. Controls work fine. Looked at the included schematic and saw that the only item in the microwave circuit that could cause the behavior is a single relay, designated as "Relay 2", that would be failed in a closed position. Found on a circuit board a relay labeled RY2 that ohm metered out as closed. The Technical Data sheet does not show the position or the circuit board that has that relay so I'm asking two questions. Since the only relay that has any markings with the number 2 is that one, is it a likely culprit and if it is what board do I need to order to replace it? It's on a largish CB at the top center of the oven, tucked in towards the rear of the oven. The multi-cables from the front panel controls and display are plugged into it. I can see no designation on the Tech data sheet or on the board that is visible without a full removal.
Thanks in advance for any advice.
Fred
Related Models
General Electric SCB2000FBB01 Counter top microwave
General Electric SCB2000FBB02 Counter top microwave
General Electric SCB2000FBB03 Counter top microwave
General Electric SCB2000FCC01 Counter top microwave
General Electric SCB2000FCC02 Counter top microwave
General Electric SCB2000FCC03 Counter top microwave
General Electric SCB2000FWW01 Counter top microwave
General Electric SCB2000FWW02 Counter top microwave
General Electric SCB2000FWW03 Counter top microwave
General Electric SCB2001CSS03 Counter top microwave
General Electric SCB2001FSS01 Counter top microwave
General Electric SCB2001FSS02 Counter top microwave
General Electric SCB2001KSS01 Counter top microwave
General Electric SCB2001KSS02 Counter top microwave
General Electric SCBC2000CBB001 SPEEDCOOK/MICROWAVE
General Electric SCBC2000CBB01 Counter top microwave
General Electric SCBC2000CCC001 SPEEDCOOK/MICROWAVE
General Electric SCBC2000CCC01 Counter top microwave
General Electric SCBC2000CWW001 SPEEDCOOK/MICROWAVE
General Electric SCBC2000CWW01 Counter top microwave
General Electric SCBC2001CSS001 SPEEDCOOK/MICROWAVE
General Electric SCBC2001CSS01 Counter top microwave
Amana SCD19H REF - SXS/I&W
Amana SCD19J REF - SXS/I&W
Amana SCD22J REF - SXS/I&W
Amana SCD22NL REF - SXS/I&W
Amana SCD22NW REF - SXS/I&W
Amana SCD22TBL REF - SXS/I&W
Amana SCD22TBW REF - SXS/I&W
Amana SCD23VBL REF - SXS/I&W
Amana SCD23VBW REF - SXS/I&W
Amana SCD23VL REF - SXS/I&W
Amana SCD23VW REF - SXS/I&W
Amana SCD25J REF - SXS/I&W
Amana SCD25JB REF - SXS/I&W
Amana SCD25JP REF - SXS/I&W
Amana SCD25N2L REF - SXS/I&W
Amana SCD25N2W REF - SXS/I&W
Amana SCD25NL REF - SXS/I&W
Amana SCD25NW REF - SXS/I&W
Amana SCD25TBL REF - SXS/I&W
Amana SCD25TBW REF - SXS/I&W
Amana SCD25TL REF - SXS/I&W
Amana SCD25TW REF - SXS/I&W
Thermador SCD272T BUILT-IN ELECTRIC OVEN
Thermador SCD302T BUILT-IN ELECTRIC OVEN
Amana SCDE25J REF - SXS/I&W
Amana SCDT20H REF - SXS/I&W
Amana SCDT22H REF - SXS/I&W
Amana SCDT25H REF - SXS/I&W
Jenn-Air SCE30500B RANGE- S/C S/I ELE
Jenn-Air SCE30500W RANGE- S/C S/I ELE
Jenn-Air SCE30600B RANGE- S/C S/I ELE
Jenn-Air SCE30600BC RANGE- S/C S/I ELE
Jenn-Air SCE30600W RANGE- S/C S/I ELE
Jenn-Air SCE30600WC RANGE- S/C S/I ELE
Jenn-Air SCE4320B RANGE- S/C S/I ELE
Jenn-Air SCE4320W RANGE- S/C S/I ELE
Jenn-Air SCE4340B RANGE- S/C S/I ELE
Jenn-Air SCE4340B-C RANGE- S/C S/I ELE
Jenn-Air SCE4340W RANGE- S/C S/I ELE
Jenn-Air SCE4340W-C RANGE- S/C S/I ELE
Jenn-Air SCE70600B RANGE- S/C S/I ELE
Jenn-Air SCE70600W RANGE- S/C S/I ELE
Whirlpool SCF0710HQ00 CHEST
Whirlpool SCF0710HQ01 CHEST
Whirlpool SCF0710HW00 CHEST FREEZER
Whirlpool SCF0710HW01 CHEST FREEZER
Whirlpool SCF0710HW05 CHEST FREEZER
Whirlpool SCF0710KQ00 CHEST FREEZER
Whirlpool SCF0710KQ01 CHEST FREEZER
Whirlpool SCF0710KQ02 CHEST FREEZER
Whirlpool SCF0710KQ03 CHEST FREEZER
Whirlpool SCF0710KQ04 CHEST FREEZER
Whirlpool SCF1510HW00 CHEST FREEZER
Whirlpool SCF1510HW02 CHEST FREEZER
Whirlpool SCF1510HW05 CHEST FREEZER
Jenn-Air SCG20200A RANGE- S/C S/I GAS
Jenn-Air SCG20200B RANGE- S/C S/I GAS
Jenn-Air SCG20200W RANGE- S/C S/I GAS
Thermador SCM-1 SPEED CONTROL
Maytag SCM10DB12 CONVENT GAS CARTRIDGE
Maytag SCM20DB11 GAS GRILLE CARTRIDGE
Whirlpool SCS3004GN0 30" GAS COOKTOP
Whirlpool SCS3004GN1 GAS COOKTOP
Whirlpool SCS3004GS0 30" GAS COOKTOP
Whirlpool SCS3004GS1 GAS COOKTOP
Whirlpool SCS3004GS2 GAS COOKTOP
Whirlpool SCS3004GV1 GAS COOKTOP
Whirlpool SCS3004GV2 GAS COOKTOP
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer turns on when door is closed kbharbison Dryer Repair 1 06-10-2013 02:16 AM
Microwave always running when door is closed Toolman102466 Microwave Repair 0 09-26-2010 08:46 AM
turntable turns when door is closed and no cooking going on ezduzit62 Microwave Repair 0 12-30-2009 12:50 PM
General Electric Advantium 120 Microwave door replacement. rhamilton1 Microwave Repair 1 11-18-2009 04:11 PM
GE Advantium Microwave Door Replace APBethesda Microwave Repair 0 10-07-2009 03:42 PM
