Discuss
Reduced heat from over the range microwave
 in
Microwave Repair
Our house cleaners used a bit too much water to clean the over the range whirlpool gold microwave a while
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Reduced heat from over the range microwave
  #1 (permalink)
Old 07-27-2013, 01:49 PM
Junior Member
natarajnv is on a distinguished road
Default Reduced heat from over the range microwave
Brand: Whirlpool   Age: 5 - 10 years
Our house cleaners used a bit too much water to clean the over the range whirlpool gold microwave a while back. The first time we used it after words we saw a bit of steam - ever since the microwave works, but at a much lower power level. Usually it takes 2 to 4 times as long to heat. Sometimes it just doesn't heat, as well.
Electricians we contacted just wanted to replace the unit - which would cost a few hundred for the microwave plus a few hundred for the installation.
What do you think is wrong with the microwave ? Will I be able to repair it ? Are there any service companies that come home and repair it (I'm near Seattle, WA) ?
Thanks in advance.
  #2 (permalink)
Old 08-01-2013, 05:13 PM
Senior Member
scott5495 is on a distinguished road
Default heat
on the touch panel there should be a power level button. press this button and make sure the number is 0. this is the highest level of heat. they may have inadvertently changed the setting while cleaning the key pad.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Microwave Range hood - All functions but silent, no heat cheapjeep2 Microwave Repair 0 02-02-2012 07:21 AM
Whirlpool Microwave over the range won't heat up viper376 Microwave Repair 1 01-01-2012 12:59 PM
over the range Microwave will not heat pdeclerck Microwave Repair 4 09-23-2010 01:48 PM
Microwave won't heat, over the range Mcrw. mbradyla Microwave Repair 11 01-25-2010 06:17 PM
Whirlpool over the range microwave won't heat bowski4 Microwave Repair 0 11-07-2009 11:28 AM
