Discuss
Did I damage this microwave?
 in
Microwave Repair
My landlord deducted $200 from my security deposit because he claims I damaged microwave by running it empty. I had
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Did I damage this microwave?
  #1 (permalink)
Old 07-22-2013, 02:23 PM
Junior Member
serenityenterprises is on a distinguished road
Default Did I damage this microwave?
Brand: Kenmore   Age: 1 - 5 years
My landlord deducted $200 from my security deposit because he claims I damaged microwave by running it empty. I had contacted the landlord and told him it was damaged when I ran it with or without anything in it. After it started sparking with food in it, I took food out and ran for a few seconds to see if it was still sparking and it was. I did that to see if perhaps there was a problem with the plate. Now he is saying I misused and damaged it.
I went to Sears Repair showing them pictures of inside microwave and they said that this is normal wear and tear and I could not have damaged it. They also said is was magnatron going bad and it was repairable.
Not only is landlord trying to take advantage of me, he's using my money to buy a brand new microwave for his unit.
Is it possible for me to damage a microwave by running it for a few seconds with nothing in it? This was AFTER the microwave was malfunctioning with food in it?
I am planning to take him to small claims court.
  #2 (permalink)
Old 07-27-2013, 12:36 PM
Senior Member
scott5495 is on a distinguished road
Default damage
worked on microwaves for 30 years. you did not damage the microwave. it would have to run several minutes to cause a problem and then it would probably trip the mag tube fuse or possibly the main fuse. interiors of microwaves can develop a condition called loading. it is usually in corners or where the paint is coming off. just normal wear. the only way to damage would be to cook several minutes with nothing in it or cook with metal in it. should kick fuses even then
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
water damage ? stevesxm Refrigerator & Freezer Repair 8 06-19-2012 06:48 AM
Microwave steam damage died frankcott11221 Microwave Repair 0 11-16-2010 04:28 PM
flood damage squier3 Washer Repair 2 09-23-2010 12:14 AM
Power Surge Damage jeparady Oven Repair (including Ranges and Cooktops) 0 02-13-2009 07:07 PM
