Discuss
Microwave with bad HV transformer and magnetron?
 in
Microwave Repair
Hey folks Is it possible to have a transformer and a magnetron go out at the same time. All other
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Microwave with bad HV transformer and magnetron?
  #1 (permalink)
Old 05-28-2013, 05:22 AM
Junior Member
hkaldrid is on a distinguished road
Default Microwave with bad HV transformer and magnetron?
Model Number: MVH250W   Brand: Amana   Age: More than 10 years
Hey folks
Is it possible to have a transformer and a magnetron go out at the same time. All other functions work, but it won't heat. And, yes, before someone asks why I don't buy another, Amana is not made anymore and 1) all other models to fit space sit 1.5 inches lower than this model (making me lose valuable pots space on cooktop); 2) no other model has the optional features we use the most (timer, light over cooktop, defrost mode) exept at $600-700 range.
Diode tests fine. HV capacitor tests fine. Cement fuse fine. Magnetron - filament leads, 0-1ohm, filament-to-ground 1.5 ohms (not infinity); HV transformer - primary coil - 0.1 ohm; filament leads - 0 ohm; HV coil-to-ground - infinity (open). There are no visible burns/discolration from arcing of HV on transformer or magnetron. I do not check cracks in magnets as readings all off on magnetron. When ran through heating cycle, low-level humming heard.
HV transformer long longer available.
Suggestions?
Related Models
Amana MVH250W MWAVE - FAMILY SIZE (60 HZ)
Amana MVH320E MWAVE- MOUNTED OVER RANGE/WO
Amana MVH320L MWAVE- MOUNTED OVER RANGE/WO
Amana MVH320W MWAVE- MOUNTED OVER RANGE/WO
Amana MVH330E MWAVE - FAMILY SIZE (60 HZ)
Amana MVH330L MWAVE - FAMILY SIZE (60 HZ)
Amana MVH330W MWAVE - FAMILY SIZE (60 HZ)
Amana MVH340E MWAVE- MOUNTED OVER RANGE/WO
Amana MVH340L MWAVE - FAMILY SIZE (60 HZ)
Amana MVH340W MWAVE - FAMILY SIZE (60 HZ)
Amana MVH350C HOOD
Amana MVH350C MWAVE - FAMILY SIZE (60 HZ)
Amana MVH350E MWAVE - FAMILY SIZE (60 HZ)
Amana MVH350L MWAVE - FAMILY SIZE (60 HZ)
Amana MVH350SS MWAVE - FAMILY SIZE (60 HZ)
Amana MVH350W MWAVE - FAMILY SIZE (60 HZ)
Amana MVP211 MWAVE - FAMILY SIZE (60 HZ)
Maytag MVP5000TQ0 LAUNDRY TOWER
Maytag MVP8600TB0 LAUNDRY TOWER
Maytag MVP8600TU0 LAUNDRY TOWER
Maytag MVP8600TW0 LAUNDRY TOWER
Maytag MVP9000TB0 LAUNDRY TOWER
Maytag MVP9000TU0 LAUNDRY TOWER
Maytag MVP9000TW0 LAUNDRY TOWER
Maytag MVWB300WQ0 AUTOMATIC WASHER
Maytag MVWB300WQ1 AUTOMATIC WASHER
Maytag MVWB400VQ0 AUTOMATIC WASHER
Maytag MVWB450WQ0 AUTOMATIC WASHER
Maytag MVWB450WQ1 AUTOMATIC WASHER
Maytag MVWB700VQ0 AUTOMATIC WASHER
Maytag MVWB750WB0 AUTOMATIC WASHER
Maytag MVWB750WB1 AUTOMATIC WASHER
Maytag MVWB750WL0 AUTOMATIC WASHER
Maytag MVWB750WL1 AUTOMATIC WASHER
Maytag MVWB750WQ0 AUTOMATIC WASHER
Maytag MVWB750WQ1 AUTOMATIC WASHER
Maytag MVWB750WR0 AUTOMATIC WASHER
Maytag MVWB750WR1 AUTOMATIC WASHER
Maytag MVWB800VB0 AUTOMATIC WASHER
Maytag MVWB800VQ0 AUTOMATIC WASHER
Maytag MVWB800VU0 AUTOMATIC WASHER
Maytag MVWB850WB0 AUTOMATIC WASHER
Maytag MVWB850WB1 AUTOMATIC WASHER
Maytag MVWB850WL0 AUTOMATIC WASHER
Maytag MVWB850WL1 AUTOMATIC WASHER
Maytag MVWB850WQ0 AUTOMATIC WASHER
Maytag MVWB850WQ1 AUTOMATIC WASHER
Maytag MVWB850WR0 AUTOMATIC WASHER
Maytag MVWB850WR1 AUTOMATIC WASHER
Maytag MVWC300VW0 AUTOMATIC WASHER
Maytag MVWC300VW1 AUTOMATIC WASHER
Maytag MVWC400VW0 AUTOMATIC WASHER
Maytag MVWC400VW1 AUTOMATIC WASHER
Maytag MVWC450WW0 AUTOMATIC WASHER
Maytag MVWC500VW0 AUTOMATIC WASHER
Maytag MVWC500VW1 AUTOMATIC WASHER
Maytag MVWC5ESXW0 AUTOMATIC WASHER
Maytag MVWC6ESWW0 AUTOMATIC WASHER
Maytag MVWC6ESWW1 AUTOMATIC WASHER
Maytag MVWC700VJ0 AUTOMATIC WASHER
Maytag MVWC700VJ1 AUTOMATIC WASHER
Maytag MVWC700VW0 AUTOMATIC WASHER
Maytag MVWC700VW1 AUTOMATIC WASHER
Maytag MVWC7ESWW0 AUTOMATIC WASHER
Maytag MVWX500XL0 AUTOMATIC WASHER
Maytag MVWX500XW0 AUTOMATIC WASHER
Maytag MVWX550XW0 AUTOMATIC WASHER
Maytag MVWX600XW0 AUTOMATIC WASHER
Maytag MVWX700XL0 AUTOMATIC WASHER
Maytag MVWX700XW0 AUTOMATIC WASHER
Whirlpool MW1000XP0 Microwaves*
Whirlpool MW1000XP1 Microwaves*
Whirlpool MW1000XS0 MICROWAVE
Whirlpool MW1000XS1 Microwaves*
Whirlpool MW1000XW0 Microwaves*
 MW1030BA MWAVE- CNTRTP / STAND ALONE
 MW1030SB MWAVE- CNTRTP / STAND ALONE
 MW1030SB/XAA MWAVE- CNTRTP / STAND ALONE
 MW1030WA MWAVE- CNTRTP / STAND ALONE
 MW1040BC MWAVE- CNTRTP / STAND ALONE
 MW1040BC/XAA MWAVE- CNTRTP / STAND ALONE
 MW1040WC MWAVE- CNTRTP / STAND ALONE
 MW1040WC/XAA MWAVE- CNTRTP / STAND ALONE
 MW1080STA MWAVE- CNTRTP / STAND ALONE
 MW1135WB MWAVE- CNTRTP / STAND ALONE
 MW1135WB/XAA MWAVE- CNTRTP / STAND ALONE
 MW1150WA MWAVE- CNTRTP / STAND ALONE
Whirlpool MW1200XP0 Microwaves*
Whirlpool MW1200XP1 Microwaves*
Whirlpool MW1200XS0 Microwaves*
Whirlpool MW1200XS1 MICROWAVE
Whirlpool MW1200XW0 Microwaves*
Whirlpool MW120EXP0 Microwaves*
 MW1245BB MWAVE- CNTRTP / STAND ALONE
Whirlpool MW1500XP0 Microwaves*
Whirlpool MW1500XP1 Microwaves*
Whirlpool MW1500XS0 Microwaves*
Whirlpool MW1500XS1 Microwaves*
Whirlpool MW1500XW0 Microwaves*
Whirlpool MW1501XS1 Microwaves*
Whirlpool MW1501XW0 Microwaves*
Roper MW157 Microwave
Maytag MW29000TB0 LAUNDRY WORKSURFACE
Maytag MW29000TU0 LAUNDRY WORKSURFACE
Maytag MW29000TW0 LAUNDRY WORKSURFACE
Whirlpool MW3000XM0 Microwaves*
Whirlpool MW3000XM1 Microwaves*
Whirlpool MW3000XP0 Microwaves*
Whirlpool MW3000XP1 Microwaves*
Whirlpool MW3000XP2 Microwaves*
Whirlpool MW3200XM0 Microwave
Whirlpool MW3200XM1 Microwave
Whirlpool MW3200XP0 Microwave
Whirlpool MW3200XP1 Microwave
Whirlpool MW3200XP2 Microwave
Whirlpool MW3200XS0 Microwave
  #2 (permalink)
Old 05-28-2013, 04:08 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
Assuming that all the measurements are correct ti does seems like both -transformer and magnetron are bad. The magnetron
8206570
For the transformer replacement you can try the QBP product. Depends on your microwave output for 700-800 watts 16QBP0293 and for 900-1000 watts 16QBP0296
Good luck.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
microwave transformer schematic rjreed Microwave Repair 7 02-14-2013 11:59 AM
Microwave HV Transformer Output Test maui4max Microwave Repair 1 01-03-2013 11:57 AM
Wirlpool Micorwave blows fuse when I press start magnetron or transformer wetpinkpants Oven Repair (including Ranges and Cooktops) 1 10-03-2010 11:19 PM
Microwave transformer installation jackie chaney Microwave Repair 0 01-08-2010 04:42 PM
microwave transformer jeffringulet Microwave Repair 2 06-17-2009 10:08 AM
