Discuss
Hotpoint Micro will not turn on
 in
Microwave Repair
My Hotpoint Counter Saver Plus will not turn on. I have checked the breaker and it is not tripped. Any
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Hotpoint Micro will not turn on
  #1 (permalink)
Old 10-06-2009, 08:18 AM
Junior Member
flasch is on a distinguished road
Default Hotpoint Micro will not turn on
Brand: Hotpoint   Age: 5 - 10 years
My Hotpoint Counter Saver Plus will not turn on. I have checked the breaker and it is not tripped. Any body know of a reset?
  #2 (permalink)
Old 10-08-2009, 12:06 PM
Senior Member
applianceman is on a distinguished road
Default
The fuse may be blown. Remove the font griddle then the control panel. Once the control panel is off you should see a fuse. You can check this fuse with an ohmmeter but if you donít have one just replace it because it is most likely your problem. Microwave Repair Guide
  #3 (permalink)
Old 10-08-2009, 12:15 PM
Junior Member
Default
Thanks. Worked out perfectly. Thanks again
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
micro wave will not turn on deamit1 Microwave Repair 2 09-22-2009 06:01 AM
Micro will not heat msexton63 Microwave Repair 0 09-18-2009 02:47 PM
micro wave light won't turn off micro wave does not turn on. Tim Bennett Microwave Repair 1 08-27-2008 02:25 PM
Hotpoint Micro wave lamps gtucker1 Microwave Repair 4 02-28-2008 12:33 PM
Micro is dead Joni Microwave Repair 1 10-19-2007 05:01 PM
