I need to replace the door on my Whirlpool microwave. I got the old door off. Now I can't seem to figure out how to get the upper pin into the door so that it is tight. I place the lower pin first and then then I am supposed to put the upper pin in and it won't go all the way. Am I supposed to hammer it in? Do I need to take part of the door apart? I found directions in a manual on line and to remove the door it said to pry back part of the choke. That really didn't seem to help. Thanks, Cynthia
