I purchased a replacement door handle from Sharon this week. The top screw is easily removed. However, the choke trim remains firmly in place after removing top screw. The trim has to be removed to access the second screw at the bottom of the door. Any help or suggestions on the process of removing the choke trim would be greatly appreciated. Thanks !!!
