Discuss
Samsung microwave power failure - Help on door latch terminal test
 in
Microwave Repair
My Samsung microwave had a power failure about 6 months ago. The problem was resolved by unplugging the cord, removing
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Samsung microwave power failure - Help on door latch terminal test
  #1 (permalink)
Old 03-26-2013, 09:03 PM
Junior Member
MinnTwin is on a distinguished road
Default Samsung microwave power failure - Help on door latch terminal test
Model Number: SHM9187W   Brand: Samsung   Age: 1 - 5 years
My Samsung microwave had a power failure about 6 months ago. The problem was resolved by unplugging the cord, removing the front display panel, then pulling and re‑installing the 2 high voltage fuses (250V-20A) on the board behind the display panel. After reassembly and plugging in the cord, the microwave powered on until this last Tuesday.
Complete power failure again.
The Microwave-Repair-Help web page (Appliancepartspros.com) indicated that the power failure may be due to a defective door switch and describes how to test the terminals with a volt-ohm meter as follows:
Bad door switch [/font]
If your microwave does not work at all and you know everything is plugged in properly and the outlet is functioning, then also check the door hooks and the door release button. Using a volt-ohm meter on RX1, check your terminals. When your microwave door is closed you should have a reading of zero. Once the door is open the reading should change to infinity. If these readings do not match up, replacement of the door switch is necessary.
However, I need help on performing the test. Where are the terminals located? There are 3 switches adjacent to (left of) the front display panel - 2 located behind the bottom door latch and 1 located behind the top door latch. All 3 switches have two terminals, one terminal protrudes (sticks out) farther than the other terminal.
Which switch provides main power to the microwave oven? Because sometimes if I wiggle one or both bottom door switches or the wire harnesses, the main power is restored!!
PLEASE HELP!?!?!
Thanks,
MinnTwin
Followup: If no LEDs on the display panel light up, do I have a complete power failure? If so, How can I check if there is current across the terminals??
MinnTwin
Related Models
Whirlpool SHU30011 DISHWASHER
Bosch SHU3002
Whirlpool SHU30041 DISHWASHER
Bosch SHU3006
Bosch SHU3012
Whirlpool SHU30140 DISHWASHER
Whirlpool SHU30141 DISHWASHER
Bosch SHU3016
Bosch SHU3032 UC/06 (FD 7908-8002)
Bosch SHU3032 UC/11 (FD 8002-8003)
Bosch SHU3032 UC/12 (FD 8003-)
Bosch SHU3035 UC/12 (FD 8006-)
Bosch SHU3036 UC/06 (FD 7908-8002)
Bosch SHU3036 UC/11 (FD 8002-8003)
Bosch SHU3036 UC/12 (FD 8003-)
Bosch SHU3132 UC/12 (FD 8105-)
Bosch SHU3135 UC/12 (FD 8105-)
Bosch SHU3136 UC/12 (FD 8105-)
Bosch SHU3302 UC/06 (FD 7902-8003)
Bosch SHU3302 UC/11 (FD 8003-8003)
Bosch SHU3302 UC/12 (FD 8003 -)
Bosch SHU3305 UC/06 (FD 7902-8003)
Bosch SHU3305 UC/11 (FD 8003-8003)
Bosch SHU3305 UC/12 (FD 8003 -)
Bosch SHU3306 UC/06 (FD 7902-8003)
Bosch SHU3306 UC/11 (FD 8003-8003)
Bosch SHU3306 UC/12 (FD 8003 -)
Bosch SHU3307 UC/12 (FD 8005 -)
Bosch SHU3322 UC/06
Bosch SHU3322 UC/11
Bosch SHU3322 UC/12
Bosch SHU3322 UC/12 (FD 8003-)
Bosch SHU3326 UC/06
Bosch SHU3326 UC/11
Bosch SHU3326 UC/12
Bosch SHU3326 UC/12 (FD 8003-)
Bosch SHU3336 UC/06
Bosch SHU3336 UC/11
Bosch SHU3336 UC/12
Bosch SHU3336 UC/12 (FD 8003-)
Bosch SHU33A02 UC/14 (FD 8211-)
Bosch SHU33A06 UC/14 (FD 8211-)
Bosch SHU33AC02 UC/14
Bosch SHU33AC06 UC/14
Whirlpool SHU40011 DISHWASHER
Bosch SHU4002 UC/06
Whirlpool SHU40041 DISHWASHER
Bosch SHU4006 UC/06
Bosch SHU4016 UC/06
Bosch SHU4022 UC/06
Bosch SHU4026 UC/06
Bosch SHU4036 UC/06
Bosch SHU4302 UC/06 (FD 7705-7912)
Bosch SHU4302 UC/11 (FD 8001-8003)
Bosch SHU4302 UC/12 (FD 8003-)
Bosch SHU4306 UC/06 (FD 7705-7912)
Bosch SHU4306 UC/11 (FD 8001-8003)
Bosch SHU4306 UC/12 (FD 8003-)
Bosch SHU4312 UC/06 (FD 7701-7912)
Bosch SHU4312 UC/11 (FD 8001-8003)
Bosch SHU4312 UC/12 (FD 8003-)
Bosch SHU4316 UC/06
Bosch SHU4316 UC/11
Bosch SHU4316 UC/12
Bosch SHU4322 UC/12
Bosch SHU4322 UC/12 (FD 8003-)
Bosch SHU4326 UC/12
Bosch SHU4326 UC/12 (FD 8003-)
Bosch SHU43C02 UC/14 (FD 8211-)
Bosch SHU43C05 UC/14 (FD 8211-)
Bosch SHU43C06 UC/14 (FD 8211-)
Bosch SHU43C07 UC/14 (FD 8211-)
Bosch SHU43E02 UC/14 (FD 8211-)
Bosch SHU43E05 UC/14 (FD 8211-)
Bosch SHU43E06 UC/14 (FD 8211-)
Bosch SHU43E07 UC/14 (FD 8211-)
Whirlpool SHU45010 Dishwasher
Whirlpool SHU45020 Dishwasher
Whirlpool SHU50041 Dishwasher
Whirlpool SHU50043 Dishwasher
Bosch SHU5302 UC/06 (FD 7705-7912)
Bosch SHU5302 UC/11 (FD 8001-8003)
Bosch SHU5302 UC/12 (FD 8003-)
Bosch SHU5304 UC/06 (FD 7705-7912)
Bosch SHU5304 UC/11 (FD 8001-8003)
Bosch SHU5304 UC/12 (FD 8003-)
Bosch SHU5305 UC/06 (FD 7705-7912)
Bosch SHU5305 UC/11 (FD 8001-8003)
Bosch SHU5305 UC/12 (FD 8003-)
Bosch SHU5306 UC/06 (FD 7705-7912)
Bosch SHU5306 UC/11 (FD 8001-8003)
Bosch SHU5306 UC/12 (FD 8003-)
Bosch SHU5307 UC/12 (FD 8003-)
Bosch SHU5312 UC/06
Bosch SHU5312 UC/11
Bosch SHU5312 UC/12
Bosch SHU5314 UC/06
Bosch SHU5314 UC/11
Bosch SHU5314 UC/12
Bosch SHU5315 UC/06
Bosch SHU5315 UC/06 (FD 7705-7912)
Bosch SHU5315 UC/11
Bosch SHU5315 UC/11 (FD 8001-8003)
Bosch SHU5315 UC/12
Bosch SHU5315 UC/12 (FD 8003-)
Bosch SHU5316 UC/06
Bosch SHU5316 UC/11
Bosch SHU5316 UC/12
Bosch SHU5317 UC/12
Bosch SHU53A02 UC/14 (FD 8211-)
Bosch SHU53A05 UC/14 (FD 8211-)
Bosch SHU53A06 UC/14 (FD 8211-)
Bosch SHU53E02 UC/14 (FD 8211-)
Bosch SHU53E05 UC/14 (FD 8211-)
Bosch SHU53E06 UC/14 (FD 8211-)
Whirlpool SHU55010 Dishwasher
Whirlpool SHU55040 Dishwasher
Whirlpool SHU55042 Dishwasher
Whirlpool SHU60020 Dishwasher
Bosch SHU66C02 UC/14 (FD 8211-)
Last edited by MinnTwin : 04-02-2013 at 06:57 PM. Reason: Main Power restored if door switch is wiggled!!!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Samsung door latch repair grebholz Microwave Repair 6 03-16-2013 12:13 PM
How to test door latch and speed control board Bucky6563 Washer Repair 5 05-31-2012 03:58 PM
Door Latch failure tracybarranco Washer Repair 1 10-13-2011 07:45 PM
Litton Microwave No Power Failure Bob B Microwave Repair 2 09-12-2009 04:48 PM
Microwave total power failure ldmartin328 Microwave Repair 0 01-12-2009 01:57 PM
