Discuss
Microwave made crackin/popping sound-now no heat
 in
Microwave Repair
My Electrolux microwave Model # PLMV 169 DCD does not heat. I ran the microwave while cooking a St. Patricks
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Microwave made crackin/popping sound-now no heat
  #1 (permalink)
Old 03-23-2013, 11:16 AM
Junior Member
rjcampbell0506 is on a distinguished road
Default Microwave made crackin/popping sound-now no heat
Brand: Electrolux   Age: 5 - 10 years
My Electrolux microwave Model # PLMV 169 DCD does not heat. I ran the microwave while cooking a St. Patricks Day dinner of boiled corned beef, cabbage, and potatoes on the stove range underneath the micro.There was a ton of steam and moisture rising into the microwave. At some point there was a loud noise which sounded like glass cracking. At first I thought it was the range's ceramic glass surface as I had 4 pots of boiling water on it. I later discovered that the food I was reheating in the microwave did not heat. The microwave turns on, the turntable spins, it sounds louder than normal but DOES NOT heat the food. Help !
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Pot over-flowed, cooktop made 2 popping sounds kbuicker Oven Repair (including Ranges and Cooktops) 3 09-10-2012 10:43 AM
Microwave Has Loud Popping Sound newatappliancerepair Microwave Repair 0 08-05-2012 05:41 PM
Popping sound Aelray Oven Repair (including Ranges and Cooktops) 1 10-06-2011 01:59 PM
Dryer made popping sound smelled hot and now will not power on Chadslack Dryer Repair 1 01-13-2010 08:48 AM
Microwave doesn't heat,has an odor, popping sound aroeder1 Microwave Repair 0 08-31-2009 07:42 AM
