Appliance Repair Forum
-   Microwave Repair (http://forum.appliancepartspros.com/microwave-repair/)
-   -   maytag microwave won't heat up (http://forum.appliancepartspros.com/microwave-repair/52076-maytag-microwave-wont-heat-up.html)
dick2256@hotmail.com 10-04-2009 07:32 AM
All runs but won't heat
I found the rectifier diode coming off of the hv capacitor
open would that keep it from heating up or do I need to search some more
cap checks ok.
Dick2256
ApplianceJunk 10-04-2009 10:11 AM
Sounds like a bad diode.
If you have a ohm meter make sure the magnetron is not shorted out to ground before you replace the diode.
dick2256@hotmail.com 10-04-2009 12:15 PM
bad diode
I tried anpother diode from another machine that was about the same physical size and it didn't help
I also tried another magnetron that wasn't the same number and it would start but then would shut down
