Discuss
TCO (thermal cut off) for Advantium
 in
Microwave Repair
My GE Advantium microwave would lose power intermittently. When it finally went dead I checked the Hood TCO & found
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » TCO (thermal cut off) for Advantium
  #1 (permalink)
Old 03-18-2013, 12:04 PM
Junior Member
perijon is on a distinguished road
Default TCO (thermal cut off) for Advantium
Model Number: SCA2000BWW003   Brand: GE   Age: 5 - 10 years
My GE Advantium microwave would lose power intermittently. When it finally went dead I checked the Hood TCO & found it had lost continuity. I ordered a new Hood TCO & after receiving it I confirmed it had continuity then installed it. I plugged the microwave back in to the outlet & everything powered up fine except now the fan blows continuously. I checked the continuity on the Oven Cavity TCO & found it closed, thus (I believe) feeding constant power to the fan. I ordered a Oven Cavity TCO, but AppliancePartPros order history shows the first TCO I purchased was an Oven Cavity TCO. I suspect that might be a typo because I'm under the assumption the continuity on an Oven Cavity TCO should be open unless/until a certain temperature is reached & when that happens the TCO connection will close to power up the fan & cool the oven. So, if I indeed replaced the Hood TCO with an Oven Cavity TCO wouldn't the microwave be without power since the Oven Cavity TCO has an open connection? Am I correct in assuming the Hood TCO should show closed & the Oven Cavity TCO should show open? That when these respective TCOs are triggered, the Hood TCO will cut off power to protect the unit while the Oven Cavity TCO connects to power to cool itself down?
Ads By Google
Related Models
General Electric SCA2000BWW03 Counter top microwave
General Electric SCA2000BWW04 Counter top microwave
General Electric SCA2000FBB01 Counter top microwave
General Electric SCA2000FBB03 Counter top microwave
General Electric SCA2000FCC01 Counter top microwave
General Electric SCA2000FCC03 Counter top microwave
General Electric SCA2000FWW01 Counter top microwave
General Electric SCA2000FWW03 Counter top microwave
General Electric SCA2001BSS03 Counter top microwave
General Electric SCA2001FSS01 Counter top microwave
General Electric SCA2001FSS02 Counter top microwave
General Electric SCA2001FSS03 Counter top microwave
General Electric SCA2001KSS01 Counter top microwave
General Electric SCB1000KBB01 Counter top microwave
General Electric SCB1000KBB02 Counter top microwave
General Electric SCB1000KCC01 Counter top microwave
General Electric SCB1000KCC02 Counter top microwave
General Electric SCB1000KWW01 Counter top microwave
General Electric SCB1000KWW02 Counter top microwave
General Electric SCB1001KSS01 Counter top microwave
General Electric SCB1001KSS02 Counter top microwave
General Electric SCB2000CAA03 Counter top microwave
General Electric SCB2000CBB03 Counter top microwave
General Electric SCB2000CCC03 Counter top microwave
General Electric SCB2000CWW03 Counter top microwave
General Electric SCB2000FBB01 Counter top microwave
General Electric SCB2000FBB02 Counter top microwave
General Electric SCB2000FBB03 Counter top microwave
General Electric SCB2000FCC01 Counter top microwave
General Electric SCB2000FCC02 Counter top microwave
General Electric SCB2000FCC03 Counter top microwave
General Electric SCB2000FWW01 Counter top microwave
General Electric SCB2000FWW02 Counter top microwave
General Electric SCB2000FWW03 Counter top microwave
General Electric SCB2001CSS03 Counter top microwave
General Electric SCB2001FSS01 Counter top microwave
General Electric SCB2001FSS02 Counter top microwave
General Electric SCB2001KSS01 Counter top microwave
General Electric SCB2001KSS02 Counter top microwave
General Electric SCBC2000CBB00 Counter top microwave
General Electric SCBC2000CBB001
General Electric SCBC2000CBB01 Counter top microwave
General Electric SCBC2000CCC00 Counter top microwave
General Electric SCBC2000CCC001
General Electric SCBC2000CCC01 Counter top microwave
General Electric SCBC2000CWW00 Counter top microwave
General Electric SCBC2000CWW001
General Electric SCBC2000CWW01 Counter top microwave
General Electric SCBC2001CSS00 Counter top microwave
General Electric SCBC2001CSS001
General Electric SCBC2001CSS01 Counter top microwave
Amana SCD19H Ref - SXS/I&W
Amana SCD19J Ref - SXS/I&W
Amana SCD22J Ref - SXS/I&W
Amana SCD22NL Ref - SXS/I&W
Amana SCD22NW Ref - SXS/I&W
Amana SCD22TBL Ref - SXS/I&W
Amana SCD22TBW Ref - SXS/I&W
Amana SCD23VBL Ref - SXS/I&W
Amana SCD23VBW Ref - SXS/I&W
Amana SCD23VL Ref - SXS/I&W
Amana SCD23VW Ref - SXS/I&W
Amana SCD25J Ref - SXS/I&W
Amana SCD25JB Ref - SXS/I&W
Amana SCD25JP Ref - SXS/I&W
Amana SCD25N2L Ref - SXS/I&W
Amana SCD25N2W Ref - SXS/I&W
Amana SCD25NL Ref - SXS/I&W
Amana SCD25NW Ref - SXS/I&W
Amana SCD25TBL Ref - SXS/I&W
Amana SCD25TBW Ref - SXS/I&W
Amana SCD25TL Ref - SXS/I&W
Amana SCD25TW Ref - SXS/I&W
Thermador SCD272T
Thermador SCD302T
Amana SCDE25J Ref - SXS/I&W
Amana SCDT20H Ref - SXS/I&W
Amana SCDT22H Ref - SXS/I&W
Amana SCDT25H Ref - SXS/I&W
Jenn-Air SCE30500B Range - S/c S/i Ele
Jenn-Air SCE30500W Range - S/c S/i Ele
Jenn-Air SCE30600B Range - S/c S/i Ele
Jenn-Air SCE30600BC Range - S/c S/i Ele
Jenn-Air SCE30600W Range - S/c S/i Ele
Jenn-Air SCE30600WC Range - S/c S/i Ele
Jenn-Air SCE4320B Range - S/c S/i Ele
Jenn-Air SCE4320W Range - S/c S/i Ele
Jenn-Air SCE4340B Range - S/c S/i Ele
Jenn-Air SCE4340B-C Range - S/c S/i Ele
Jenn-Air SCE4340W Range - S/c S/i Ele
  #2 (permalink)
Old 03-18-2013, 12:54 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
You should replace the cavity thermostat. It's normally closed. The one you replaced - the hood thermostat is normally open and close on temperature rise to turn the blower on.
Here are the breakdown diagrams and Unit parts for GE SCA2000BWW03 - AppliancePartsPros.com
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 03-18-2013, 01:44 PM
Junior Member
Default
Quote:
Originally Posted by Simon / APP Team View Post
Hi.
Simon.
Thanks. I just need to clarify with you. The Base Hood TCO (1432 in the diagram) allows power to flow through the unit (closed) & shuts down (open) when sensing excessive heat coming in through the hood vents, etc. The Cavity TCO (1430 in the diagram) is normally open & only provides power (closed) to automatically operate the fan & cool the unit when sensing excessive heat in the oven cavity. Is that correct? And if I had replaced the Base Hood TCO (closed) with a Cavity TCO (open) I shouldn't be getting any power in the unit. Is that correct?
Also, I had disconnected the cavity thermostat (1435 in the diagram) intitally to simulate it being in an open position, but the fan continued to operate. If it were a bad thermostat shouldn't the fan have shut off?
Thanks again.
  #4 (permalink)
Old 03-18-2013, 02:44 PM
Expert
Default
Could you please read my previous post.
Simon.
__________________
  #5 (permalink)
Old 03-19-2013, 08:25 AM
Junior Member
Default
Simon.
I have & understand all of what you wrote, however, it doesn't address the issue I'm having with the TCO replacement part I ordered v. received. Anyway, I appreciate your time & thank you all the same.
  #6 (permalink)
Old 03-19-2013, 10:42 AM
Expert
Default
You are welcome.
Simon.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Advantium 120 Oven Terry K Microwave Repair 1 04-19-2013 07:25 PM
Advantium 120 GBGB Microwave Repair 0 07-16-2012 11:31 AM
ge advantium noise lawrenb1 Microwave Repair 0 05-28-2011 09:41 AM
GE Advantium 120 stephenb Microwave Repair 0 05-09-2011 07:29 AM
Advantium f6 code AMAPPLIANCE Microwave Repair 0 12-24-2008 07:25 AM
