| » How To Remove Screw At Bottom Of Handle |
Model Number: JVM1490SD003 Brand: GE Age: 1 - 5 years
I am replacing a handle(WB15X10069 on my microwave). I was able to remove from the inside part of the door the edge rim cover plate; and then I was able to remove the screw that holds the top of the handle. I was not able to see the screw that secures the bottom of the handle. I did try to remove another part that I believe is covering the screw at the bottom. I also removed 6 screws I believe is holding that particular part; and even then I still couldn't remove that part to uncover the screw head.
How will I be able to expose that screw that needs to be removed? Thank you, Ernie Ads By Google Related Models |
| Display Modes | |
| wrench to remove hex screw to replace ignitor | hgbcpa | Dryer Repair | 1 | 03-12-2012 11:52 AM |
| wrench to remove hex screw | hgbcpa | Washer Repair | 1 | 03-12-2012 10:51 AM |
| Accessing lower screw on microwave door handle | jrfyrfytr | Microwave Repair | 1 | 10-08-2011 07:06 AM |
| Screw in bottom of tub | anne836 | Washer Repair | 1 | 05-28-2009 06:53 PM |
| remove a lost screw | Brian Robinson | Dishwasher Repair | 2 | 12-12-2008 12:43 PM |
