Service Manual
Anyone have service manual for Jenn-Air JMC8130DDS?
I have only been able to finf the Owners and Installation manuals . Basically want to know how to get at the turntable motor. Cheers, Mark |
Hi Mark,
Remove the turntable tray and the ring. Turn over the oven on its back. Cut 6 joints of the bottom plate using diagonal pliers. Separate the motor cover from the bottom plate. remove two screws securing the turntable motor to the cavity and take it out. - The turntable motor Part number: W10207571 Here are the breakdown diagrams and Parts for Jenn-Air JMC8130DDS Microwave - AppliancePartsPros.com Gene. |
Thanks Gene,
I remember seeing that plate and was wondering if could be removed. After removing whats best method to re-atach. Cheers, Mark |
You are welcome Mark. I'm nor sure what are those joints made from. They are not listed in the parts list.
Gene. |
| All times are GMT -7. The time now is 01:16 AM. |
