Discuss
Micro runs but no heat
 in
Microwave Repair
I have a microwave that runs fine but will not heat. I tested all the micro switches and they are
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Micro runs but no heat
  #1 (permalink)
Old 02-06-2013, 07:06 AM
Junior Member
scuba505 is on a distinguished road
Default Micro runs but no heat
Model Number: MMV4203DS00   Brand: Maytag   Age: 1 - 5 years
  1. I tested all the micro switches and they are functioning correctly.
  2. I tested the 2 internal 20 amp fuses and their ok.
  3. I tested HV fuse on magnatron, tests ok.
  4. I tested the HV Diode with the 9 volt battery trick and it is fuctioning fine. I did replace it anyway because it was so cheap but it did not help.
  5. I tested the HV Capacitor and it is not shorted to ground and when you connect an ohm meter across the leads it reads ohms then gradually goes towards infinity, seems ok.
  6. I tested the magnatron and there are no shorts to ground and across the two terminals its .2 ohms, seems ok.
  7. I check to see if the HV transformer was getting 120v power when the microwave was plug in and it is on the black.
  8. I tested the HV transformer by ohming it out with the specs given but its a little confussing. I know what the primary and secondary winding are but what wires should I test? There is blue/white, black filament and two reds and white to the magnatron/capacitor.
  9. Lastly in following the schematic I noticed the two secondary relays on the control board. The neutral wire passing through both relays is tied into the door safetys and other controls but in testing, relay #1 does not seem to close allowing the neutral circuit to complete to power the HV transformer. What do you think?
Ads By Google
Related Models
Maytag MMV4203DS00 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Maytag MMV4203DW00 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Maytag MMV4203WB0 MICROWAVE OVEN/HOOD 2.0 CU. FT.
Maytag MMV4203WQ0 MICROWAVE OVEN/HOOD 2.0 CU. FT.
Maytag MMV4203WS0 MICROWAVE OVEN/HOOD 2.0 CU. FT.
Maytag MMV4203WW0 MICROWAVE OVEN/HOOD 2.0 CU. FT.
Maytag MMV4205AAB MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV4205AAQ MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV4205AAS MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV4205AAW MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV4205BAB MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV4205BAB14 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Maytag MMV4205BAB17 MICROWAVE OVEN/HOOD 2.0 CU. FT.
Maytag MMV4205BAQ MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV4205BAQ14 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Maytag MMV4205BAQ17 MICROWAVE OVEN/HOOD 2.0 CU. FT.
Maytag MMV4205BAS MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV4205BAS14 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Maytag MMV4205BAS17 MICROWAVE OVEN/HOOD 2.0 CU. FT.
Maytag MMV4205BAW MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV4205BAW15 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Maytag MMV4205BAW18 MICROWAVE OVEN/HOOD 2.0 CU. FT.
Maytag MMV5000ADA MWAVE- MOUNTED UNDER CABINET
Maytag MMV5000ADB MWAVE- MOUNTED UNDER CABINET
Maytag MMV5000ADW MWAVE- MOUNTED UNDER CABINET
Maytag MMV5000BAB MWAVE- MOUNTED UNDER CABINET
Maytag MMV5000BAC MWAVE- MOUNTED UNDER CABINET
Maytag MMV5000BAQ MWAVE- MOUNTED UNDER CABINET
Maytag MMV5000BAW MWAVE- MOUNTED UNDER CABINET
Maytag MMV5000BDB MWAVE- MOUNTED UNDER CABINET
Maytag MMV5000BDC MWAVE- MOUNTED UNDER CABINET
Maytag MMV5000BDQ MWAVE- MOUNTED UNDER CABINET
Maytag MMV5000BDW MWAVE- MOUNTED UNDER CABINET
Maytag MMV5100AAB MWAVE- MOUNTED UNDER CABINET
Maytag MMV5100AAQ MWAVE- MOUNTED UNDER CABINET
Maytag MMV5100AAS MWAVE- MOUNTED UNDER CABINET
Maytag MMV5100AAW MWAVE- MOUNTED UNDER CABINET
Maytag MMV5156AAB MWAVE- MOUNTED UNDER CABINET
Maytag MMV5156AAQ MWAVE- MOUNTED UNDER CABINET
Maytag MMV5156AAS MWAVE- MOUNTED UNDER CABINET
Maytag MMV5156AAW MWAVE- MOUNTED UNDER CABINET
Maytag MMV5156ACB MWAVE- MOUNTED UNDER CABINET
Maytag MMV5156ACQ MWAVE- MOUNTED UNDER CABINET
Maytag MMV5156ACS MWAVE- MOUNTED UNDER CABINET
Maytag MMV5156ACW MWAVE- MOUNTED UNDER CABINET
Maytag MMV5165AAB MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5165AAQ MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5165AAS MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5165AAW MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5165BAB MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5165BAB14 Microwave Oven/Hood 1.6 Cu. Ft.
Maytag MMV5165BAB15 MICROWAVE OVEN/HOOD 1.6 Cu. Ft.
Maytag MMV5165BAS MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5165BAS14 Microwave Oven/Hood 1.6 Cu. Ft.
Maytag MMV5165BAS15 MICROWAVE OVEN/HOOD 1.6 Cu. Ft.
Maytag MMV5165BAW MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5165BAW15 Microwave Oven/Hood 1.6 Cu. Ft.
Maytag MMV5165BAW16 MICROWAVE OVEN/HOOD 1.6 Cu. Ft.
Maytag MMV5186AAB MWAVE- MOUNTED UNDER CABINET
Maytag MMV5186AAQ MWAVE- MOUNTED UNDER CABINET
Maytag MMV5186AAS MWAVE- MOUNTED UNDER CABINET
Maytag MMV5186AAW MWAVE- MOUNTED UNDER CABINET
Maytag MMV5186ACB MWAVE- MOUNTED UNDER CABINET
Maytag MMV5186ACQ MWAVE- MOUNTED UNDER CABINET
Maytag MMV5186ACS MWAVE- MOUNTED UNDER CABINET
Maytag MMV5186ACW MWAVE- MOUNTED UNDER CABINET
Maytag MMV5201DB00 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Maytag MMV5201DS00 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Maytag MMV5201DW00 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Maytag MMV5207AAB MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207AAQ MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207AAS MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207AAW MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207ACB MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207ACQ MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207ACS MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207ACW MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207BAB MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207BAB14 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BAB17 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Maytag MMV5207BAQ MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207BAQ14 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BAQ17 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Maytag MMV5207BAS MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207BAS14 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BAS17 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Maytag MMV5207BAW MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207BAW15 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BAW18 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Maytag MMV5207BCB MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207BCB14 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BCB17 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BCB18 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BCQ MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207BCQ14 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BCQ17 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BCQ18 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BCS MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207BCS14 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BCS17 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BCS18 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BCW MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207BCW15 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BCW18 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BCW19 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5208WB0 MICROWAVE OVEN/HOOD 2.0 CU. FT.
Maytag MMV5208WQ0 MICROWAVE OVEN/HOOD 2.0 CU. FT.
Maytag MMV5208WS0 MICROWAVE OVEN/HOOD 2.0 CU. FT.
Maytag MMV5208WW0 MICROWAVE OVEN/HOOD 2.0 CU. FT.
Maytag MMV6178AAB MICROWAVE - CONVECTION
Maytag MMV6178AAQ MICROWAVE - CONVECTION
Maytag MMV6178AAS MICROWAVE - CONVECTION
Maytag MMV6178AAW MICROWAVE - CONVECTION
Maytag MMV6180WB0 Microwave Oven/Hood 1.8 Cu. Ft.
Maytag MMV6180WS0 Microwave Oven/Hood 1.8 Cu. Ft.
Maytag MMV6180WW0 Microwave Oven/Hood 1.8 Cu. Ft.
Maytag MMV6186WB0 Microwave Oven/Hood 1.8 Cu. Ft.
Maytag MMV6186WS0 Microwave Oven/Hood 1.8 Cu. Ft.
Maytag MMV6186WW0 Microwave Oven/Hood 1.8 Cu. Ft.
Maytag MMW5527BAB WALLOVEN- S/C ELE
  #2 (permalink)
Old 02-06-2013, 01:11 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
HI.
Remove the plug from the transformer's primary winding and check if there is 120VAC with the MW turned on.If you have correct voltage - replace the magnetron (it lost the vacuum) Part number: W10126786
If not - there is the problem with the control board.
Here are the breakdown diagrams and 03-Interior and Ventilation Parts parts for Maytag MMV4203DS00 - AppliancePartsPros.com
Post the results.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 02-06-2013, 06:17 PM
Junior Member
Default
Replaced the magnetron and it's working again.
  #4 (permalink)
Old 02-07-2013, 11:42 AM
Expert
Default
You are welcome.
Simon.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Micro does heat pearsonn Microwave Repair 1 04-24-2012 01:39 PM
GE micro runs but no Heat bmoore196767 Microwave Repair 1 10-06-2010 08:42 AM
GE Micro does not heat Scojo75 Microwave Repair 0 09-11-2010 01:48 PM
Sharp Micro Only runs for 59 seconds attitude Microwave Repair 1 05-28-2010 06:12 AM
Micro will not heat msexton63 Microwave Repair 0 09-18-2009 02:47 PM
