| » In Dilemma: RCCB, Magnetron, Capacitor, HVT |
Model Number: D80D20ESLR-DK Brand: -other- Age: 1 - 5 years
My sparingly used (just for about 10 mins twice a day) 4 year old ONIDA brand 20 lts Combine Grill and Convection Microwave oven (Model No. 20CJS25... I looked up the web and found it to be actually manufactured by Galanz (Model No. D80D20ESLR-DK) on a dedicated 220v AC power supply from a Mains Board equipped with a 63Amp RCCB to trip @ 100mA leakage and then via a 20Amp rated MCB for the dedicated line. Please see fig.1
Of late, I observe that the Main Power Supply RCCB (Residual Current Circuit Breaker) trips with the oven in IDLE mode within seconds of connecting the MW to the power supply. However the 20Amp rated MCB doesn't trip at all. Some times I'm able to warm food for about a minute or two before the RCCB trips.
Would be immensely thankful if someone could please help me pinpoint the defect. Thanks in advance. Sorry I missed this info... the internal 20amp ceramic fuse has not blown its ok.. shows continuity ... Ads By Google Related Models Last edited by MISTRAL : 02-06-2013 at 07:02 AM. |
Alright, I went about the technique of deduction by elimination to narrow on the faulty component. So I hooked up every thing as it was in the case and went one by one with the segments.
1. First to be on check was the PCB panel with the micro switches and relays and the electronics. The HVT, Magnetron and the HV Cap and Diode, disconnected. Observation: 1. The Panel LEDs lit up normal... no error codes 2. The timers worked 3. The cooking modes were accepted ( the glass would rotate after 4-5 sec of selecting the cooking modes 4. As anticipated a tumbler with water did not warm 5. Best of all the RCCB or the MCB did not trip Deduction 1: The problem may not be here, but probably may be with the High Voltage Transformer (HVT) or the Magnetron or the HV Capacitor or the HV Diode. 2. I had already checked the HVT for continuity using digi meter set at 200 ohm. The primary winding showed 2 ohm resistance. The HV terminals had abt 8ohms between them. Observed no continuity between body and the terminals except between a terminal which goes to the HV Cap and another connected to the core of the transformer and the reading at 2k and 20k settings showed about 300 ohms. I connected the input terminals to this transformer but left the High Voltage output to the Maganetron and the Capacitor open and plugged the device to the mains. Observation: 1. The Panel LEDs lit up normal... no error codes 2. The timers worked 3. The cooking modes were accepted ( the glass would rotate after 4-5 sec of selecting the cooking modes 4. As anticipated a tumbler with water did not warm 5. Best of all the RCCB or the MCB did not trip Deduction 2: The problem may not be HVT, but probably may be with the the Magnetron or the HV Capacitor or the HV Diode. 3. I had already checked the Magnetron for continuity using digi meter set at 200 ohm. The filament showed 7 ohm resistance. The HV terminals had no continuity between them or between any of the terminals and the body at 20K, 2M, 20M, 200M or even at lower settings. I connected the HV terminals of the HVT to the Magnetron but left the HV Cap connections open. Observation: 1. The Panel LEDs lit up normal... no error codes 2. The timers worked 3. The cooking modes were accepted ( the glass would rotate after 4-5 sec of selecting the cooking modes 4. However a tumbler with water did not warm 5. Best of all the RCCB or the MCB did not trip Deduction 3: Probably the Magnetron also seems to be OK, but dunno how correct I am, because the tumbler of water DID NOT WARM UP even with the Magnetron now connected. 4. This time I connected the HV capacitor (Please See Attached Pict) too but left the HV Diode unconnected. I had already checked the HV cap with my multimeter with the 10M ohm shunt resistor and the diode removed and had found that though there was no continuity between the terminals of the HV Cap, the low charge between the two terminals dropped rather abruptly than gradually. I had also checked the HV Diode and found it functioning as it should fwd and rev direction after connecting it in series with the Digi Meter to a 12V DC supply. The 10M ohm Resistor read 10m ohms on the 200M ohm scale of the Digi meter. Keeping my fingers crossed I connected the MW to the power supply. waited for 5 minutes on stand by mode and later started the oven as in the earlier tests. Observation: 1. The Panel LEDs lit up normal... no error codes 2. The timers worked 3. The cooking modes were accepted ( the glass would rotate after 4-5 sec of selecting the cooking modes 5. As was during the earlier tests, the convection and grill modes produced heat 4. But, this time too a tumbler with water did not warm 5. Best of all unlike when the problem was first noticed when the RCCB or the MCB would trip even on standby mode,they did not trip now Deduction 4: Already beginning to feel that the capacitor seems ok, now left is the Diode. However, when the oven did not warm the tumbler of water even a bit I'm still unable to discount the Magnetron. ANOTHER IMPORTANT OBSERVATION: AFTER THE LAST OF THE TESTS ABOVE, I TRIED DISCHARGING THE HV CAPACITOR MOMENTS AFTER SWITCHING OFF THE MICROWAVE, BY SHORTING THE LEADS OF THE HV CAP, BUT FAILED TO NOTICE ANY HV SPARK OR CRACKLE. PROBABLY ITS BECAUSE OF THE 10M ohm SHUNT RESISTOR BUT NOT SO CONVINCED THAT THE DISCHARGE CAN BE SO SWIFT. SO NOW I AM WONDERING IF AT ALL THE HV TRANSFORMER IS PRODUCING ANY HIGH VOLTAGE. Question: 1.Is there a way to know if the HVT is ok with out holding a well insulated screwdriver near the HT terminal to see if there is high voltage spark bridge as the TV techies of the yester years did? Though I have a screw driver with a 5kv insulation I dont want to attempt that. 2. I wish someone could tell me which of thse seems most likely to be at fault, the magnetron, the HVT or the HV Cap. 3. I wish some one could enlighten me if the magnetron works only when the capacitor is connected. Shall be grateful if some one could throw some light... Thanks in advance. Edit: I forgot to mention, I checked the thermostat and found it in order too contacts closed in normal condition... Last edited by MISTRAL : 02-08-2013 at 12:30 AM. Reason: added information |
No matter how strange this may sound... with no responses or any ideas to get ahead with coming by, I decided to check out the HVT. after seeing videos on the net about how dangerous it could be trying to fathom the HV strength from the HVT, I thought of a round about way to see if the transformer was doing its work.
I took out the HVT once again and fed the transformer about 1/20 th the rated ac input which is about 12DC pulses @ 3amp (since I did not have a standalone step down transformer to feed 12v ac from my auxiliary 12v/3Amp DC power supply) by intermittently touching one of the input terminals while the other terminal of the 12V Dc was clamped to the other input terminal of the HVT. I had clamped the multimeter terminals to the high voltage secondary at 750 v ac range. I got a 200v step up deflection every time I touched the input terminal. Though a crude assessment but a positive indication that the HVT was working. Now remained the HV Capacitor and its HV Diode. since the RCCB and the MCB would not trip with the capacitor connected, I decided to go ahead and connect the High Voltage Diode (quite sure by now, that this was the culprit). The microwave that would not heat, with just the capacitor connected, was now working again and warming the water in the tumbler. I repeated the warming process a few more time... It was heating now every time like before. I put the oven in stand by and the MCB and the RCCB does not trip now... its working like new again... Dunno what caused the malfunction, but the experience has brought me more insight about the working of Microwave ovens and the dangers stored inside it... I strongly feel that a connector here or a connector there must have loosened due to variation in temperatures inside the oven causing it to malfunction. I hope my account of experiences will help others like me who may not be professionally connected with electricity and maintenance, but who by virtue of their interest and experience in electronics and electricals can do enough to maintain their own appliances and gadgets. It looks like as it has happened many times in the past with other appliances, I have been saved from spending at least 500 bucks on account of a techies visit, if not anything for spares. Though I am an architect by profession, I have a passion for electronics and electricals from an early childhood age and this background spanning over 3and a half decades helped me a lot in many a diagnosis and test. Lookes like it has come to my help again. I agree its rather a bit too early to rejoice, I'm keeping my fingers crossed and hope the situation holds. Will post again if there is a change. Thanks everyone for your patience, support and for stopping by. |
| Display Modes | |
| Help! Replaces Diode,Capacitor,Magnetron and fuse...still not working correctly... | rcshadows | Microwave Repair | 0 | 05-05-2012 07:49 PM |
| Fastener Dis-Connect Dilemma | jcrow | Microwave Repair | 1 | 01-16-2012 09:14 PM |
| Bosch Dilemma | cgourzong | Oven Repair (including Ranges and Cooktops) | 1 | 05-11-2011 10:23 PM |
| Repair Dilemma | mephamrog | Washer Repair | 6 | 02-05-2008 06:35 AM |
