Discuss
Microwave
 in
Microwave Repair
My double convection-micro oven has no power to the microwave. It turns on and the timer counts down normally, but
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Microwave
  #1 (permalink)
Old 02-04-2008, 09:24 AM
Junior Member
bouffard is on a distinguished road
Question Microwave
Model Number: CMT227NPRS   Brand: Thermador   Age: More than 10 years
My double convection-micro oven has no power to the microwave. It turns on and the timer counts down normally, but there is no microwave heating. Any suggestions on the possible parts responsible.
Ads By Google
Related Models
Thermador CMT227W
Thermador CMT231-01 S/N 89110145 & UP
Maytag CMV1000ADA Mwave - Mounted Under Cabinet
Maytag CMV1000ADB Mwave - Mounted Under Cabinet
Maytag CMV1000ADW Mwave - Mounted Under Cabinet
Maytag CMV1000BAB Mwave - Mounted Under Cabinet
Maytag CMV1000BAQ Mwave - Mounted Under Cabinet
Maytag CMV1000BAW Mwave - Mounted Under Cabinet
Maytag CMV1000BDB Mwave - Mounted Under Cabinet
Maytag CMV1000BDQ Mwave - Mounted Under Cabinet
Maytag CMV1000BDW Mwave - Mounted Under Cabinet
Maytag CMV1100AAB Mwave - Mounted Under Cabinet
Maytag CMV1100AAQ Mwave - Mounted Under Cabinet
Maytag CMV1100AAW Mwave - Mounted Under Cabinet
Crosley CMW159PC Mwave - Cntrtp / Stand Alone
Crosley CMW22A2 Mwave - Cntrtp / Stand Alone
Crosley CMW22A6 Mwave - Cntrtp / Stand Alone
Crosley CMW419PD Mwave - Cntrtp / Stand Alone
Crosley CMW464G Mwave - Cntrtp / Stand Alone
Maytag CNDNS229J  Ref - SXS/I&W
Maytag CNDNS229JA  Ref - SXS/I&W
Maytag CNDNS229JH  Ref - SXS/I&W
Maytag CNDNS229K  Ref - SXS/I&W
Maytag CNDNS229KA  Ref - SXS/I&W
Maytag CNE200 Range - F/s Std Ele
Maytag CNE2000ACL Range - F/s Std Ele
Maytag CNE2000ACW Range - F/s Std Ele
Admiral CNEA100ACL Range - F/s Std Ele
Admiral CNEA100ACW Range - F/s Std Ele
Maytag CNG200 Range - F/s Std Gas
Maytag CNG201 Range - F/s Std Gas
Maytag CNG2010AAL Range - F/s Std Gas
Maytag CNG2010AAW Range - F/s Std Gas
Maytag CNG2010BAL Range - F/s Std Gas
Maytag CNG2010BAW Range - F/s Std Gas
Maytag CNNS208  Ref - Sxs
Maytag CNNS208H  Ref - Sxs
Norge CNNS208K Ref - Sxs
Norge CNNS208KA Ref - Sxs
Norge CNNS208KW Ref - Sxs
Maytag CNNT153L  Ref - Top Mount
Maytag CNNT153LA  Ref - Top Mount
Maytag CNNT156K  Ref - Top Mount
Maytag CNNT156KA  Ref - Top Mount
Maytag CNNT156KH  Ref - Top Mount
Maytag CNNT156KL  Ref - Top Mount
Norge CNNT174HL Ref - Top Mount
Norge CNNT174HLA Ref - Top Mount
Norge CNNT174HLH Ref - Top Mount
Maytag CNNT174K  Ref - Top Mount
Maytag CNNT174KA  Ref - Top Mount
Maytag CNNT174KL  Ref - Top Mount
Maytag CNNT174KLA  Ref - Top Mount
Norge CNNT178BV Ref - Top Mount
Norge CNNT178BVA Ref - Top Mount
Norge CNNT178BVH Ref - Top Mount
Maytag CNNT198GA  Ref - Top Mount
Maytag CNNT198GH  Ref - Top Mount
Maytag CNNT198GL Ref - Top Mount
Maytag CNNT198GLA  Ref - Top Mount
Maytag CNNT198GLH  Ref - Top Mount
Maytag CNNT198GLN Ref - Top Mount
Maytag CNNT198GN  Ref - Top Mount
Maytag CNNT198K  Ref - Top Mount
Maytag CNNT198KA  Ref - Top Mount
Maytag CNNT198KL  Ref - Top Mount
Maytag CNNT198KLA  Ref - Top Mount
Crosley CNNT218BV Ref - Top Mount
Crosley CNNT218BVA Ref - Top Mount
Crosley CNNT218BVH Ref - Top Mount
Maytag CNP200 Range - F/s Std Gas
Maytag CNP201 Range - F/s Std Gas
Maytag CNP2010AXL Range - F/s Std Gas
Maytag CNP2010AXW Range - F/s Std Gas
Maytag CNP2010BXL Range - F/s Std Gas
Maytag CNP2010BXW Range - F/s Std Gas
Admiral CNPA100AXL Range - F/s Std Gas
Admiral CNPA100AXW Range - F/s Std Gas
Crosley CNS20M4 Ref - Sxs
Crosley CNS20M4A Ref - Sxs
Crosley CNS20M4H Ref - Sxs
Crosley CNS20M6 Ref - Sxs
Crosley CNS20M6A Ref - Sxs
Crosley CNS20M6H Ref - Sxs
Crosley CNS20T6 Ref - Sxs
Crosley CNS20T6A Ref - Sxs
Crosley CNS20T6H Ref - Sxs
Crosley CNS22M6 Ref - Sxs
Crosley CNS22M6A Ref - Sxs
Crosley CNS22M6H Ref - Sxs
Crosley CNS22T6 Ref - Sxs
Crosley CNS22T6A Ref - Sxs
Crosley CNS22T6H Ref - Sxs
Crosley CNS22V6 Ref - Sxs
Crosley CNS22V6A Ref - Sxs
Crosley CNS22V8 Ref - Sxs
Crosley CNS22V8A Ref - Sxs
  #2 (permalink)
Old 02-04-2008, 06:32 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Does the indicator light go "on" when the microwave is running?
If it does then the problem is with a part on the high voltage side - most likely the magnetron.
If it does not, then the next thing I would check is the fuse, the door interlock switch (under the left side upper oven door hinge, the primary interlock switch (the top switch on the latch assembly) and the secondary interlock switch (the lower switch on the latch assembly).
All of these switches are normally open or, another word, they should show ∞ Ohms when the door or the door latch are open and 0 Ohms when the door or the door latch are closed.
There is also the door monitor switch (under the right side upper oven door hinge). This switch is normally closed (0 Ohms with the door open and ∞ Ohms with the door closed).
To access the door switches the oven has to be removed from the cabinet for about 20".
- Here are the break down diagrams for the Thermador tri-mode oven Model CMT227N-01
Post your findings, please.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 02-08-2008, 09:18 AM
Junior Member
Default
The power light is not on. I took the oven out and found the fuse blown. I bypassed it temporarily and the microwave is working. I'll have to get a new fus and see if it blows again.
Thanks for the quick response. I'll follow up if I find any other problems.
Bouffard
  #4 (permalink)
Old 02-08-2008, 12:00 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Bouffard,
The part number for the fuse is AP2825415 and APP has it in stock.
__________________
  #5 (permalink)
Old 02-23-2008, 04:07 PM
Junior Member
Default
I bought the fuse from APP and it's been installed for about two weeks and the microwave is working great. Thanks again for the help.
  #6 (permalink)
Old 02-24-2008, 09:47 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I'm glad you were able to fix it.
__________________
  #7 (permalink)
Old 02-24-2008, 04:17 PM
Junior Member
Angry Microwave
Hi Gene,
Tonight, after telling you it's fixed, the fuse must have blown again. Do you think it's worth trying to replace the magnetron or should I just get out my checkbook and buy a new one. It is getting a little old, but I hate to spend the big bucks if I can fix it.
Thanks again.
Brian
  #8 (permalink)
Old 02-24-2008, 04:41 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Brian,
I believe the blown fuse has nothing to do with the magnetron. I would check all the switches first.
__________________
  #9 (permalink)
Old 02-29-2008, 05:03 AM
Senior Expert
APP Volunteer
Servicer is on a distinguished road
Default
As Gene mentioned above, check the monitor switch mounted on the right side hinge assembly. There may be an alignment issue, which can cause an intermittent blown fuse.
The Thermador number for this switch is 414529.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool microwave door will not open and microwave not working bbowen Microwave Repair 5 07-21-2010 08:55 PM
GE Covection/Microwave Convection works, microwave doesn't Sticks1947 Microwave Repair 4 07-11-2009 10:18 PM
whirpool microwave does not microwave soophia Microwave Repair 5 05-11-2009 10:57 AM
microwave/convection oven blows fuse when trying to microwave christop Microwave Repair 0 05-01-2009 06:40 PM
Need Microwave knobs for Gaffers/Sattler Combo Range/Microwave afleer Oven Repair (including Ranges and Cooktops) 3 11-17-2008 04:46 PM
