microwave turntable stops turning
my turntable will turn if I turn it prior to starting the micro but only for a short time then stop. Why is my turntable not working
Hi.
You need to check two things: First check if the slot in the middle of the support is intact Part number: 5304440284 Then using the multimeter check if there is 120VAC to the turn table motor when the microwave is ON. If the proper voltage is present - replace the motor Part number: 5304440021 Here are the breakdown diagrams and Oven / Cabinet parts for Frigidaire FMV156DSB - AppliancePartsPros.com Post the results. Simon. |
| All times are GMT -7. The time now is 08:22 PM. |
