| » Kitchen aid mw door error |
Model Number: KEMC378KSS01 Brand: Kitchen Aid Age: 1 - 5 years
My builtin kitchen aid mw keeps giving me door error. I checked right two primary and monitor switches and they work fine. How do I access left switch. There is vey limited access without taking everything apart
Hi.
There is a 20amp fuse behind the control panel on the right. Most likely it's blown Part number: W10017410 Here are the breakdown diagrams and Top Venting parts for Whirlpool KEMC378KSS01 - AppliancePartsPros.com Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Hi.
Most likely the fuse is blown again. You need to check the door switches with the multimeter with the door open and closed. You can get to the left side switch by pulling the microwave out for few inches. Simon.
__________________
I checked the fuse and it is good this time outside as well as continuity between terminals as installed. I did check the right two switches in open and closed door position and they seem to switch NO and NC correctly.
I have MW pulled out and can see the left side switch holder but and probably can pull out from top but I am afraid I may not be able to put it back. It has circular white plastic flange facing inside of the mcirowave. |
Hi.
To get to the secondary interlock switch with the MW out take out 6 screws and remove the left side cover. Did you remove one wire off the switch while testing? Did you check the other fuse ( it inside the MW on the right) and is smaller then the first one. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. Last edited by Simon / APP Team : 02-04-2013 at 10:42 AM. |
For your convinience I attached the instructions with a few pictures on how to remove the microwave from the oven cabinet. Hope it will help. Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Hi Simon,
May be I am not checking switch properly. Can you explain what you mean by taking one wire off ? I am following Tech Sheet, with schematic. i.e. Door open should have continuity between BR and R/BK and door closed between BU and R/BK. Also, I checked first fuse (big size, 20A) as per instructions earlier. I also checked the second small 15A inside right top (inline with 20A in schematic).Is that correct ? I have not checked secondary switch yet, I will open the side panel. Thanks for your help. |
| Display Modes | |
| Kitchen Aid microwave f2 error | Larry Bitton | Microwave Repair | 0 | 04-14-2011 04:21 AM |
| Kitchen aid microwave error code F 4 | sikennels | Microwave Repair | 0 | 01-11-2011 04:38 PM |
| Kitchen Aid Error Code F2-E3 | niagarajcs | Oven Repair (including Ranges and Cooktops) | 5 | 03-16-2009 08:02 PM |
| Kitchen Aid Microwave Error code F2 | jjmu2 | Microwave Repair | 1 | 01-03-2009 05:43 PM |
| Kitchen Aid Code Error F7 E0 | Sailn | Oven Repair (including Ranges and Cooktops) | 0 | 09-30-2007 07:25 AM |
