Discuss
je1456kwh02 Dual Wave III - fan goes on when door opened
 in
Microwave Repair
Originally Posted by Simon / APP Team Hi, Bernie. You need to replace the mounting bracket, one of the pins
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » je1456kwh02 Dual Wave III - fan goes on when door opened
  #11 (permalink)
Old 01-22-2013, 01:24 PM
Junior Member
Bernie157 is on a distinguished road
Default
Quote:
Originally Posted by Simon / APP Team View Post
Hi, Bernie.
You need to replace the mounting bracket, one of the pins holding the switch broke off and the switch is moving instead of engaging.Unfortunately this part is no longer available.
Unless you can figure out how to fix the switch to the bracket.
Simon.
Thanks again, Simon. I will have to remove the cover and try to figure how to tape that switch in place if I can. I was considering if I should remove that whole assembly which holds the 3 switches but not sure if I would totally mess things up.
Bernie
Ads By Google
  #12 (permalink)
Old 01-28-2013, 11:39 AM
Junior Member
Default
Quote:
Bernie
The microwave oven seems to have quit altogether now. I have order a new, smaller one online and hope to have it tomorrow. They are supposed to take the old one away.
Bernie
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Door Disassembly of GE Dual Wave II gte619n Oven Repair (including Ranges and Cooktops) 1 11-16-2011 04:01 PM
GE Dual Wave II Jeeplover Oven Repair (including Ranges and Cooktops) 1 08-06-2011 04:51 AM
GE Dual Wave II lucia Oven Repair (including Ranges and Cooktops) 0 07-04-2011 12:08 PM
GE Dual Wave II - seems low wattage now nickHsac Microwave Repair 0 01-16-2010 09:01 AM
GE Dual Wave not cleaning kprihoda Oven Repair (including Ranges and Cooktops) 5 09-20-2008 07:40 PM
