Appliance Repair Forum
-   Microwave Repair (http://forum.appliancepartspros.com/microwave-repair/)
-   -   Bad Microwave diode (http://forum.appliancepartspros.com/microwave-repair/515092-bad-microwave-diode.html)
maui4max 01-08-2013 10:53 PM
Bad Microwave diode
My GE Spacemaker began making a loud noise and then stopped heating. I replaced the magnetron and the noise stopped but it still didn't heat. Using a multimeter and information gleaned from this site I tested the capacitor and diode. The cap seems okay but the diode appears to be shorted. Testing the diode in both directions shows less than 1 ohm. When I connect it to a 120 v AC power source it shows 120 v in both directions.
I have two questions:
1. If I replace the diode should I replace any other component?
2. What, if any, defective component could cause the diode to go bad?
Thanks.
Mike
