Discuss
Help My LG LMVM2277ST stopped working serial # 707KMSA01310
 in
Microwave Repair
Yesterday My LG Microwave modle # LMVM2277ST just stopped working. I went to heat up some water and typed in
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Help My LG LMVM2277ST stopped working serial # 707KMSA01310
  #1 (permalink)
Old 12-20-2012, 10:38 AM
Junior Member
KJ15 is on a distinguished road
Unhappy Help My LG LMVM2277ST stopped working serial # 707KMSA01310
Model Number: LMVM2277ST   Brand: -other-   Age: 1 - 5 years
Yesterday My LG Microwave modle # LMVM2277ST just stopped working. I went to heat up some water and typed in the desired time. At first, after pressing start the microwave beeped like always but the table top did not move nor did it sound like it was running. The time on the display just ran down then beeped again once done like always. I tried it once more this time the table top rotated and the power level read 100%. Once done, I grabbed the water from the microwave but the water was still cold. After rwo more attempts with the sme resault I decided to look closer at the unit. At one time I even pressed against the upper left corner of the door for some reason and it worked for a second but then stopped. Not knowing to much about how to repair it I did what seemed lodgical and decided to clead the carbon filter hoping that was the right fix hoping that it was just clogged.
Prior cleaning the filter I noticed that all of My sensor controls seemed to work fine / display but once they were punched in and I pressed start it wouldn't work. My inside and counter top lights worked as well as My exhaust fan on all levels.
As I opened the inclosure to remove and inspect the filter I noticed a wire harness coming from the left door panel pluggingg into the unit it's self from the the door control panel. When I went to move this harness just a little to get the inclosure back in place I noticed that the harness was covered with electric tap. With a closer inspection of the wire I noticed the several of the wires were cut in half and it appeared as if someone had placed tap around them to keep them in place or hopfully together but over the course of time open and closing of the door they came apart.
Not knowing if this was the resault of My problem I spoke with a so called Tech at a local store and they assurred Me that this was not My problem and that I needed to replace the fuse because I wasn't getting enough current needed to run My LG microwave or that I had larger problems. When I questioned him about the cut wires he said that obviously someone made a mistake and taped it but they were obsolete wires and couldn't be the cause.
Like I stated, I have full display on the control panel. The clock works fine as do all the pre sets, but once I press start nothing happens. If I type in a cooking time all that happens is that the unit beeps like always and the time runs down. But now neither the fan or lights work on the unit. but I still have all the beeps and so on when I press buttons. A closer look at the wire harness which comes from the control panel to the unit it's self like i said has about 12-14 wires cut in half which can't be good. Before I start investing in parts which may or may not help can anyone please help me out just seems like the real problem is the wire harnes which makes sense to me but I'm not an expert.
Please help any advise will do Thanks.
Ads By Google
Related Models
Frigidaire LMW1350-1
Frigidaire LMW850-1
International LNC6760A71 Washer - Top Loading
Admiral LNC6760B71 Washer - Top Loading
International LNC6762A01 Washer - Top Loading
Admiral LNC6762A01 Washer - Top Loading
International LNC6762A71 Washer - Top Loading
Admiral LNC6762A71 Washer - Top Loading
International LNC6762A77 Washer - Top Loading
Admiral LNC6762A77 Washer - Top Loading
Admiral LNC6762B01 Washer - Top Loading
Admiral LNC6762B71 Washer - Top Loading
Admiral LNC6764A00 Washer - Top Loading
Admiral LNC6764A71 Washer - Top Loading
Admiral LNC6766A00 Washer - Top Loading
Admiral LNC6766A01 Washer - Top Loading
Admiral LNC6766A71 Washer - Top Loading
Admiral LNC6766A77 Washer - Top Loading
Admiral LNC6766B71 Washer - Top Loading
Admiral LNC7760A00 Dryer - Ele
Admiral LNC7760A71 Dryer - Ele
Admiral LNC7764A00 Dryer - Ele
Admiral LNC7764A71 Dryer - Ele
Admiral LNC7764A77 Dryer - Ele
Admiral LNC7766A00 Dryer - Ele
International LNC7766A00 Dryer - Ele
Admiral LNC7766A71 Dryer - Ele
International LNC7766A71 Dryer - Ele
Admiral LNC7766B71 Dryer - Ele
International LNC8760A00 Dryer - Gas
International LNC8760A01 Dryer - Gas
International LNC8760A71 Dryer - Gas
International LNC8760A77 Dryer - Gas
Admiral LNC8764A00 Dryer - Gas
Admiral LNC8764A71 Dryer - Gas
Admiral LNC8766A00 Dryer - Gas
International LNC8766A00 Dryer - Gas
Admiral LNC8766A71 Dryer - Gas
International LNC8766A71 Dryer - Gas
Admiral LNC8766B71 Dryer - Gas
Amana LP13300.A Mwave - Family Size (60 Hz)
Amana LP13300.B Mwave - Family Size (60 Hz)
Amana LP13600.A Mwave - Family Size (60 Hz)
Amana LP13600.B Mwave - Family Size (60 Hz)
Amana LP13610.A Mwave - Family Size (60 Hz)
Amana LP13610.B Mwave - Family Size (60 Hz)
Amana LP16400.A Mwave - Family Size (60 Hz)
Amana LP16400.B Mwave - Family Size (60 Hz)
Amana LP16600.A Mwave - Family Size (60 Hz)
Amana LP16600.B Mwave - Family Size (60 Hz)
Amana LP16610.A Mwave - Family Size (60 Hz)
Amana LP16610.B Mwave - Family Size (60 Hz)
Amana LP24400.A Mwave - Family Size (60 Hz)
Amana LP24400.B Mwave - Family Size (60 Hz)
Amana LP24600.A Mwave - Family Size (60 Hz)
Amana LP24600.B Mwave - Family Size (60 Hz)
Amana LP83400.A Mwave - Family Size (60 Hz)
Amana LP83400.B Mwave - Family Size (60 Hz)
Amana LP83430.A Mwave - Family Size (60 Hz)
Amana LP83430.B Mwave - Family Size (60 Hz)
Amana LP83600.A Mwave - Family Size (60 Hz)
Amana LP83600.B Mwave - Family Size (60 Hz)
Amana LP83620.A Mwave - Family Size (60 Hz)
Amana LP83630.A Mwave - Family Size (60 Hz)
Amana LP83630.B Mwave - Family Size (60 Hz)
Admiral LPK5404ARW Kitchen Compact
Admiral LPK5404ARZ Kitchen Compact
Admiral LPR1115ADW Range - F/s Std Gas
Whirlpool LPR4231AG0
Whirlpool LPR4231AN0
Whirlpool LPR4231AW0
Whirlpool LPR6244AN0
Whirlpool LPR6244AW0
Maytag LRSC20A Ref - Sxs
Maytag LRSD20A Ref - Sxs
Maytag LRSD22A Ref - Sxs
Maytag LRSD24A Ref - Sxs
Maytag LRSW22A Ref - SXS/I&W
Maytag LRSW24A Ref - SXS/I&W
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dishwasher stopped working mid-cycle, no lights working. natecobbs Dishwasher Repair 4 03-20-2011 11:48 AM
refrigerator stopped working cleaned it and started working then stopped working agai ravaginggoatman Refrigerator & Freezer Repair 5 12-18-2010 01:13 AM
Refrig and freezer stopped working, then started...then stopped again Auvan0876 Refrigerator & Freezer Repair 2 08-28-2009 07:29 PM
