Discuss
Turntable Turns with Door Opme
 in
Microwave Repair
Thanks again Gene. I have a bit more information to add. It seems that only the bake cycle will not
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Turntable Turns with Door Opme
  #11 (permalink)
Old 12-26-2012, 07:16 PM
Junior Member
ottogaus is on a distinguished road
Default
Thanks again Gene. I have a bit more information to add. It seems that only the bake cycle will not hold temperature. In the convection bake cycle, the temperature control works properly. Do you still suspect the control board and if so, is there a particular component that I could replace rather than the entire board? Any help you can provide in helping me identify the component as you did with the microwave relay would be very much appreciated! Thank you.
Ads By Google
  #12 (permalink)
Old 12-27-2012, 02:12 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
There is nothing unusual about better heating performance in the convection bake compare to regular bake. The hot air will distribute more evenly during convection because of the convection fan.
If the difference between set and real temperatures in the oven is withing 35°F, then it can be adjusted. Follow the instructions in the attached mini-manual.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #13 (permalink)
Old 12-30-2012, 07:02 PM
Junior Member
Default
Thanks Gene. Don't think the issue is the difference between the set point and the actual temperature as much as the oven not holding the temperature. The problem seems to be intermittent so i think it was just coincidence that when I changed the oven to convection bake is worked fine. I checked the resistance at the temperature sensor at the control panel connection and it tests good at about 1080 ohms. As the oven is now working properly again, could it be the sensor is on the blink? Or the control panel?? Any further suggestions on further troubleshooting to try to pinpoint the problem? Many thanks!!
  #14 (permalink)
Old 01-01-2013, 03:58 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I don't think it's a good idea to guess what it could be as long as it's working fine. Let's see what will happen later.
__________________
  #15 (permalink)
Old 01-02-2013, 05:05 AM
Junior Member
Default
Thanks Gene. I certainly agree with you about guessing. That can be very frustrating and time consuming, not to mention expensive. Only problem is that the wife does not want to use the oven until I can assure her it is fixed for fear of ruining another dish. Help!!
  #16 (permalink)
Old 01-02-2013, 01:32 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You have to get a good and reliable oven thermometer. Place in the middle of the oven cavity. Set the oven on 350°F and run it for at least 30 minutes. Then open the oven door and check the temperature.
You can do it twice - on regular bake and on convection bake.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE: Turntable turns, light on when door opens nykhoa Microwave Repair 37 06-28-2012 02:13 PM
Micorwave won't heat/turntable turns when door opens poopypants73 Microwave Repair 1 10-07-2011 07:11 PM
ge microwave turntable turns constantly mikerozell Microwave Repair 1 05-04-2010 01:02 PM
Panasonic microwave turntable turns when door opened nightdog Microwave Repair 0 02-06-2010 07:27 AM
turntable turns when door is closed and no cooking going on ezduzit62 Microwave Repair 0 12-30-2009 11:50 AM
