Microwave Repair
The touch pad screen on our microwave does not always work and sometimes when it works it does not work properly. Can this part be replaced and if so are their any instructions as to how to remove the old part and replace the new part. I would also like to know the part number and the cost of this part. This is not a counter top microwave but it is a Spacemaker 2.0.
Hi.
Unfortunately the touch screen is available only as an control panel assembly Part number: WB07X10974 You should be able to replace it with out removing the unit, after taking off the front grill. Here are the breakdown diagram and Microwave parts for GE JVM2070WH02 - AppliancePartsPros.com Simon. |
| All times are GMT -7. The time now is 03:00 PM. |
