Replace KEMC308 Microwave Bulb
Need to replace the bulb in the microwave which I have already purchased. Unit is a KEMC308KSS Oven/Micro combo. It looks like I may need to pull the door off and/or remove the front face plate to access the bulb cavity. Can anyone share or know where I can obtain Tech Repair Instructions on this? Many thanks.
Steve |
The following may help, click on it and a new page will open with a Q&A which has answers how to replace it.
Part number: AP5306958 |
Simon,
I already have the part - need detailed instructions for replacement. Thanks. Steve |
Denman,
Read all the Q&A but I do not see how to access the bulb cavity by removing the control panel. It would appear to me that I have to remove the door, then the front panel itself. I really need the Service Manual. Any idea where one can be had? Thanks. Steve |
Here is a link that may work for you.
http://appliancejunk.com/forums/inde...sa=view;id=137 You may have to join the site to get the manual but this is free. Also there is a possibility that you will have to pay for it |
| All times are GMT -7. The time now is 11:42 AM. |
