Discuss
Whirlpool accuwave Not Heating
 in
Microwave Repair
the microwave listed above quit cooking. I disassembled it and checked the following: ohmed fuse ohmed magnatron Short between terminals,
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Whirlpool accuwave Not Heating
  #1 (permalink)
Old 11-15-2012, 08:38 AM
Junior Member
John Redd is on a distinguished road
Default Whirlpool accuwave Not Heating
Model Number: GMH5205XVS   Brand: Whirlpool   Age: 1 - 5 years
ohmed fuse
ohmed magnatron Short between terminals, open-terminals to ground
checked voltage coming into inverter board- 120v
checked magnetron thermistor- closed
ohmed interlocks-good
since i had voltage coming into the inverter, my thought it must be the inverter since the magnatron ohmed ok. I replace the inverter and it did not heat at first, then it started heating. I installed it (over the range) and tested it and it heated. this morning it does not heat
i can see the magnatron glowing red inside when it was working. it has made a slight hissing noise a few times (pulsating)
unfortunately, i found this forum too late....i just read that you can order parts and return the ones you do not use! How amazing is that? I just spent $120 on this microwave for the inverter and it may not be the problem.
any suggestions will be greatly appreciated. the only thing I have not tested is the voltage/signal coming into the inverter from the control panel. it is a 3 wire plug and I cannot find any information on what the voltage/signal should be into the inverter
At this point I am thinking the magnetron is bad...or could it be the control panel and the voltage/signal on the 3 wire plug....being intermittent makes it even harder to find the right part without spending more than the microwave is worth.
Ads By Google
Related Models
General Electric GMR02AAMABB Refrigerator
General Electric GMR02AAMAWW Refrigerator
General Electric GMR02BANABB Refrigerator
General Electric GMR02BANAWW Refrigerator
General Electric GMR02BANBBB Refrigerator
General Electric GMR02BANBWW Refrigerator
General Electric GMR02BANCBB Refrigerator
General Electric GMR02BANCWW Refrigerator
General Electric GMR02BANDBB Refrigerator
General Electric GMR02BANDWW Refrigerator
General Electric GMR02CANBWW Refrigerator
General Electric GMR03DAMAWW Refrigerator
General Electric GMR04AAMABB Refrigerator
General Electric GMR04AAMAWW Refrigerator
General Electric GMR04BANABB Refrigerator
General Electric GMR04BANAWW Refrigerator
General Electric GMR04BANBBB Refrigerator
General Electric GMR04BANBWW Refrigerator
General Electric GMR04BANCBB Refrigerator
General Electric GMR04BANCWW Refrigerator
General Electric GMR04BANDBB Refrigerator
General Electric GMR04BANDWW Refrigerator
General Electric GMR04BARABS Refrigerator
General Electric GMR04BARBBS Refrigerator
General Electric GMR04BARCBS Refrigerator
General Electric GMR04HANBBS Refrigerator
General Electric GMR04HANCBS Refrigerator
General Electric GMR04HANDBS Refrigerator
General Electric GMR04HASACS Refrigerator
General Electric GMR04HASBCS Refrigerator
General Electric GMR06AAMARWW Refrigerator
General Electric GMR06AAMBRWW Refrigerator
General Electric GMR06AAPBB Refrigerator
General Electric GMR06AAPWW Refrigerator
General Electric GMS10AAMALWW Refrigerator
General Electric GMS10AAMARWW Refrigerator
Frigidaire GMT1670AS0 Frigidaire/washer
Frigidaire GMWS1339CS0 Frigidaire/washer
General Electric GN1S15CBL Uc filtration-carbon
Norge GN31113WAM Range - F/s Std Gas
Norge GN31113WAV Range - F/s Std Gas
Norge GN3177WUA Range - F/s Std Gas
Norge GN3177WUW Range - F/s Std Gas
Norge GN3277XUA Range - F/s Std Gas
Norge GN3277XUW Range - F/s Std Gas
Norge GN3531WUA Range - F/s Std Ele
Norge GN3531WUW Range - F/s Std Ele
General Electric GNCF02H Home cond
General Electric GNCF04H Home cond
Thermador GNG12M
Thermador GNG12MW
General Electric GNPR40L00 Softners
General Electric GNPR48L00 Softners
General Electric GNRP40L00 Softners
General Electric GNRP48L00 Softners
International GNS20M82 Ref - Sxs
General Electric GNSF18Z01 Uc filtration-carbon
General Electric GNSF23Z01 Uc filtration-carbon
General Electric GNSF35Z01 Uc filtration-carbon
General Electric GNSF35Z02 Water softeners
General Electric GNSF35Z03 Water softeners
General Electric GNSF35Z04 Softners
General Electric GNSF39A01 Uc filtration-carbon
General Electric GNSF48A01 Uc filtration-carbon
General Electric GNSH45E01 Water softeners
General Electric GNSH45E02 Softners
General Electric GNSH45E03 Softners
General Electric GNSL05CBL Uc filtration-carbon
General Electric GNSL60FBL Wh filt sys
General Electric GNSM48F02 Softners
General Electric GNSM48F03 Softners
General Electric GNSR3150H0WW Washer
General Electric GNSV25CBL Uc filtration-carbon
General Electric GNSV30CCC Uc filtration-carbon
General Electric GNSV30CWW Uc filtration-carbon
General Electric GNSV70FBL
General Electric GNSV70FBL01 Wh filt sys
General Electric GNSV75FWW Wh filt sys
General Electric GNSV75WW01 Wh filt sys
International GNT15M42 Ref - Top Mount
International GNT15M42A Ref - Top Mount
International GNT15M42L Ref - Top Mount
International GNT15M42LA Ref - Top Mount
International GNT15M4XA Ref - Top Mount
International GNT15M4XH Ref - Top Mount
International GNT15M82 Ref - Top Mount
International GNT17M42 Ref - Top Mount
International GNT17M42A Ref - Top Mount
International GNT17M4XA Ref - Top Mount
International GNT17M4XH Ref - Top Mount
International GNT17M92 Ref - Top Mount
International GNT19M4XA Ref - Top Mount
International GNT19M4XH Ref - Top Mount
General Electric GNUL30B01 Uc filtration-carbon
General Electric GNUL30Z01 Uc filtration-carbon
General Electric GNUT03A Uc filtration-carbon
General Electric GNUT03B01 Uc filtration-carbon
  #2 (permalink)
Old 11-15-2012, 02:42 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
hi.
If you still have the 120VAC to the inverter replace the magnetron Part number: 8206079
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 11-15-2012, 03:09 PM
Junior Member
Default
what is the voltage/signal on the 3 wire plug to the inverter? could this affect the output of the inverter?
thanks for the quick reply
  #4 (permalink)
Old 11-15-2012, 04:11 PM
Expert
Default
It's possible, but no literature can be find for this model and similar models has different wiring.
So I suggest you to try the new magnetron first. As you know it's returnable even if you install it.
Good luck.
Simon.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Dryer Not Heating Phiphtie Dryer Repair 8 01-11-2012 03:27 PM
Whirlpool not heating at all tswanny50 Oven Repair (including Ranges and Cooktops) 1 09-12-2011 05:18 AM
Accuwave lost all power TallunAK Microwave Repair 0 12-24-2010 07:55 PM
WHIRLPOOL, heating and air jackssib1 Heating, Ventilation, and Air Conditioning (HVAC) 0 06-11-2010 05:44 AM
whirlpool accuwave system sher67 Microwave Repair 0 02-25-2010 08:35 AM
