Discuss
GE Profile microwave oven - replacing the board latch
 in
Microwave Repair
Dear APP Team, Last year I replaced the faulty Primary Interlock (top) micro switch, its gone bad again. I need
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » GE Profile microwave oven - replacing the board latch
  #11 (permalink)
Old 04-07-2013, 05:50 PM
Junior Member
nj1971 is on a distinguished road
Default Ge Profile Microwave Peb1590sm1ss - Latch Board
Dear APP Team,
Last year I replaced the faulty Primary Interlock (top) micro switch, its gone bad again. I need to pull out the latch board as it needs replacement as well. I removed the 2 screws but the latch board is stuck between various plastic prongs and wouldn't come out unless I open more stuff. Need help to handle this strange design.
  #12 (permalink)
Old 04-08-2013, 10:31 AM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
Looks like you need to remove the control panel first (#923 on the diagram), one screw on top from inside.Then remove the lever (#2006) and the latch board.
Here is the breakdown diagram and Microwave parts for GE PEB1590SM1SS - AppliancePartsPros.com
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #13 (permalink)
Old 04-11-2013, 05:22 AM
Junior Member
Default
Simon / APP Team
Thanks for the response.
I did remove the latch board by loosing the top screw for the adjoining fan and breaking some of the plastic prongs.
Removing the Control Panel 923, is not likely to help since the latch board is screwed on to steel panel 281 and then stuck between the panel and the adjoining fan.
I have received the new parts and want to install it back without breaking any thing. Appreciate your quick response on this.
  #14 (permalink)
Old 04-11-2013, 03:07 PM
Expert
Default
Hi.
What I can tell you from the diagram is that removing the control panel first wil allow you to remove the lever, holding the latch board.
Simon.
__________________
  #15 (permalink)
Old 04-13-2013, 06:59 PM
Junior Member
Default
Simon
Thanks a lot. Removed the control panel #923 (FYI, it has one screw at the bottom as well). I have installed the new latch board, micro switch etc.
Just one quick question, one of the connector to the top micro switch (the one that got busted second time) shows burning signs. Although it still hold well to the micro switch connectors. Do I need to replace this?
See the attached pics.
Thanks a lot.
  #16 (permalink)
Old 04-15-2013, 11:35 AM
Expert
Default
Hi.
I highly recommend you to replace this conector.That could be the reason why the switch goes bad.
Simon.
__________________
  #17 (permalink)
Old 04-21-2013, 02:33 PM
Junior Member
Default
Hi Simon / APP Team
Thanks for the response. Agree with your recommendation.
I removed the damaged insulated 2-wire female connector, however I am not able to find the similar 2-Wire Insulated connector here. What's the part number for these so I can order these with APP.
Also will appreciate some instruction on installation of this 2 Wire female connector.
  #18 (permalink)
Old 04-22-2013, 09:35 AM
Expert
Default
Hi.
You don't need to replace the entire connector. Use the side cutters to cut off the bad one and replace it with regular crimp on connector.
Simon.
__________________
  #19 (permalink)
Old 05-13-2013, 08:01 PM
Junior Member
Default
Hi Simon
Sorry couldn't get back earlier. Thanks for your below response.
I see the regular crimp on connectors don't fit well.
I think I may end up replacing the entire connector bunch. What's the part nbr for that to order.
  #20 (permalink)
Old 05-14-2013, 11:24 AM
Expert
Default
Hi.
I don't think they are sold as a separate parts from the manufacture. I have used the regular connectors many times without any problems in the past.
Simon.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
tried replacing door latch electronic control board sparks87144 Washer Repair 1 10-13-2011 01:42 PM
Replacing display board in Microwave mw_novice Microwave Repair 0 01-25-2011 04:17 PM
whirlpool microwave GT4185SKS3 replacing door latch. DIAZ050305 Microwave Repair 0 02-03-2010 07:59 PM
replacing door latch on Kenmore microwave mizmardy Microwave Repair 0 03-31-2008 09:48 AM
Replacing Latch Spring on Microwave Door Idoitmyself Microwave Repair 1 03-25-2008 04:12 PM
