| » Whirlpool Microwave makes ticking noise then stops |
Model Number: WMH3205XVS Brand: Whirlpool Age: 1 - 5 years
There is a ticking noise coming from the ride side, behind the keypad. When you run it, it will start ticking immediately then stop after 3 seconds. Thing is about 15 months old. Doesn't matter how long you set the time for, stops after 3 seconds. Any thoughts?
Remove the upper grill and then remove the screw in the top of the control panel. Carefully lift it up and out. Start the microwave and see if you can get a better idea where the ticking is coming from.
__________________
Ricks Appliance Repair |
The only thing on the inside it a white cover with four screws. I took that off and there is just a hole there that leads upward. I cannot figure out where the control panel access is on this thing. It is an over the stove model so there aren't any real panel access on the sides and bottom. maybe it is on the back?
| Display Modes | |
| Hotpoint refrigerator makes a ticking noise | sprdav | Refrigerator & Freezer Repair | 3 | 10-26-2012 02:00 PM |
| Whirlpool Gold Microwave makes loud humming noise | jchncsu | Microwave Repair | 0 | 10-13-2012 07:58 AM |
| Washer won't agitate, makes ticking noise | brooklyn88 | Washer Repair | 1 | 09-21-2011 08:37 AM |
| Whirlpool Duet ghw9200l / qhw9100l won't drain pump makes ticking sound | homiebologna | Washer Repair | 3 | 05-13-2010 09:46 PM |
| Microwave makes ticking sounds for a few seconds then stops working | condochris | Microwave Repair | 0 | 05-14-2008 07:39 AM |
