| » Ge Jvm1653sh06 Range Hood Microwave Dead |
Model Number: JVM1653SH06 Brand: GE Age: 5 - 10 years
I have been trying to diagnose a dead microwave, no lights/response from control panel/keypad, electricity is detectable at the filter circuit board and the thermostats and they test closed. If there was once a circuit diagram inside the unit it is no longer there so I am shooting blind. At this point I am assuming that the smart board is non-functional.
Thanks for your advice Larry Ads By Google Related Models |
There is 121+v at both sides of the fuse and also at both sides of the cavity thermostat #27, both #115 thermostat's (M.G.T. and bottom) ohm'd as closed and the #110 thermostat (hood) ohm'd open as it should be. The door interlock switches are functioning correctly as is the monitor. The display is still dead so does this make the smart board the likely suspect?
Hi Larry,
Unplug the CN3 connector from the control board and check for 120 VAC between the Black & the Yellow wires at this plug. If the reading is correct, replace the smart board. If the reading is incorrect, then you did something wrong in the previous tests. - The smart board Part number: WB27X10894 Here are the breakdown diagrams and Parts for GE JVM1653SH06 Microwave - AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
| Display Modes | |
| Microwave Range hood - All functions but silent, no heat | cheapjeep2 | Microwave Repair | 0 | 02-02-2012 07:21 AM |
| Microwave range hood fan | ctdgm | Microwave Repair | 0 | 11-22-2011 08:12 AM |
| Microwave Range Hood | Lyndar | Oven Repair (including Ranges and Cooktops) | 0 | 02-15-2010 09:54 AM |
| Microwave Range Hood Lighting | PragmaticCynic | Microwave Repair | 0 | 02-09-2009 02:21 PM |
| Microwave range hood combo | cakeman | Microwave Repair | 0 | 10-12-2007 07:33 AM |
