Discuss
scrolling request for timer info; error "SE"
 in
Microwave Repair
Everything works ... except the microwave from time to time beeps and requests info for the timer (min & sec).
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » scrolling request for timer info; error "SE"
  #1 (permalink)
Old 09-02-2012, 07:17 AM
aeh aeh is offline
Junior Member
aeh is on a distinguished road
Default scrolling request for timer info; error "SE"
Model Number: MMV4203D   Brand: Maytag   Age: 1 - 5 years
Everything works ... except the microwave from time to time beeps and requests info for the timer (min & sec). Also sometimes the keypad locks up. Also sometimes "SE" appears. Is the problem:
1. Dirt/junk that might have slid down between the keypad and stainless steel trim?
2. Failing keypad -- if so, which part needs to be replaced: A. W10258190 (Panel Asy, control membrane, lens, & bracket), B. W10258265 (Bracket, control0, or C. W10258171 (Microcomputer)
I have succeed in removing the grill and pulling the keypad assembly out (of course with power off). I can't see how to separate the 3 parts in #2. [FONT='Times New Roman','serif']There are numerous side clips, screws, and electrical connections?[/font]
Also, if I just removed the grill and keypad unit, any danger from microwaves after reassembly?
Thanks.
Ads By Google
Related Models
Maytag MMV4205AAB Mwave - Mounted Over Range/wo
Maytag MMV4205AAQ Mwave - Mounted Over Range/wo
Maytag MMV4205AAS Mwave - Mounted Over Range/wo
Maytag MMV4205AAW Mwave - Mounted Over Range/wo
Maytag MMV4205BAB Mwave - Mounted Over Range/wo
Maytag MMV4205BAQ Mwave - Mounted Over Range/wo
Maytag MMV4205BAS Mwave - Mounted Over Range/wo
Maytag MMV4205BAW Mwave - Mounted Over Range/wo
Maytag MMV5000ADA Mwave - Mounted Under Cabinet
Maytag MMV5000ADB Mwave - Mounted Under Cabinet
Maytag MMV5000ADW Mwave - Mounted Under Cabinet
Maytag MMV5000BAB Mwave - Mounted Under Cabinet
Maytag MMV5000BAC Mwave - Mounted Under Cabinet
Maytag MMV5000BAQ Mwave - Mounted Under Cabinet
Maytag MMV5000BAW Mwave - Mounted Under Cabinet
Maytag MMV5000BDB Mwave - Mounted Under Cabinet
Maytag MMV5000BDC Mwave - Mounted Under Cabinet
Maytag MMV5000BDQ Mwave - Mounted Under Cabinet
Maytag MMV5000BDW Mwave - Mounted Under Cabinet
Maytag MMV5100AAB Mwave - Mounted Under Cabinet
Maytag MMV5100AAQ Mwave - Mounted Under Cabinet
Maytag MMV5100AAS Mwave - Mounted Under Cabinet
Maytag MMV5100AAW Mwave - Mounted Under Cabinet
Maytag MMV5156AAB Mwave - Mounted Under Cabinet
Maytag MMV5156AAQ Mwave - Mounted Under Cabinet
Maytag MMV5156AAS White Westinghouse/refrigerator
Maytag MMV5156AAW Mwave - Mounted Under Cabinet
Maytag MMV5156ACB Mwave - Mounted Under Cabinet
Maytag MMV5156ACQ Mwave - Mounted Under Cabinet
Maytag MMV5156ACS Mwave - Mounted Under Cabinet
Maytag MMV5156ACW Mwave - Mounted Under Cabinet
Maytag MMV5165AAB Mwave - Mounted Over Range/wo
Maytag MMV5165AAQ Mwave - Mounted Over Range/wo
Maytag MMV5165AAS Mwave - Mounted Over Range/wo
Maytag MMV5165AAW Mwave - Mounted Over Range/wo
Maytag MMV5165BAB Mwave - Mounted Over Range/wo
Maytag MMV5165BAQ Mwave - Mounted Over Range/wo
Maytag MMV5165BAS Mwave - Mounted Over Range/wo
Maytag MMV5165BAW Mwave - Mounted Over Range/wo
Maytag MMV5186AAB Mwave - Mounted Under Cabinet
Maytag MMV5186AAQ Mwave - Mounted Under Cabinet
Maytag MMV5186AAS Mwave - Mounted Under Cabinet
Maytag MMV5186AAW Mwave - Mounted Under Cabinet
Maytag MMV5186ACB Mwave - Mounted Under Cabinet
Maytag MMV5186ACQ Mwave - Mounted Under Cabinet
Maytag MMV5186ACS Mwave - Mounted Under Cabinet
Maytag MMV5186ACW Mwave - Mounted Under Cabinet
Maytag MMV5207AAB Mwave - Mounted Over Range/wo
Maytag MMV5207AAQ Mwave - Mounted Over Range/wo
Maytag MMV5207AAS Mwave - Mounted Over Range/wo
Maytag MMV5207AAW Mwave - Mounted Over Range/wo
Maytag MMV5207ACB Mwave - Mounted Over Range/wo
Maytag MMV5207ACQ Mwave - Mounted Over Range/wo
Maytag MMV5207ACS Mwave - Mounted Over Range/wo
Maytag MMV5207ACW Mwave - Mounted Over Range/wo
Maytag MMV5207BAB Mwave - Mounted Over Range/wo
Maytag MMV5207BAQ Mwave - Mounted Over Range/wo
Maytag MMV5207BAS Mwave - Mounted Over Range/wo
Maytag MMV5207BAW Mwave - Mounted Over Range/wo
Maytag MMV5207BCB Mwave - Mounted Over Range/wo
Maytag MMV5207BCQ Mwave - Mounted Over Range/wo
Maytag MMV5207BCS Mwave - Mounted Over Range/wo
Maytag MMV5207BCW Mwave - Mounted Over Range/wo
Maytag MMV6178AAB Microwave - Convection
Maytag MMV6178AAQ Microwave - Convection
Maytag MMV6178AAS Microwave - Convection
Maytag MMV6178AAW Microwave - Convection
Maytag MMW5527BAB Walloven - S/c Ele
Maytag MMW5527BAW Walloven - S/c Ele
Maytag MMW5527CAB Walloven - S/c Ele
Maytag MMW5527CAW Walloven - S/c Ele
Maytag MMW5530BAB Walloven - S/c Ele
Maytag MMW5530BAW Walloven - S/c Ele
Maytag MMW5530CAB Walloven - S/c Ele
Maytag MMW5530CAW Walloven - S/c Ele
Maytag MMW5530DAB Walloven - S/c Mwave Ele
Maytag MMW5530DAW Walloven - S/c Mwave Ele
Norge MN15E-5 Mwave - Cntrtp / Stand Alone
Norge MN15F-14T Mwave - Cntrtp / Stand Alone
Norge MN15FN-14T Mwave - Cntrtp / Stand Alone
Norge MN46G-14T Mwave - Cntrtp / Stand Alone
Norge MN46GN-14T Mwave - Cntrtp / Stand Alone
Maytag MO1450BA Mwave - Mounted Over Range/wo
Maytag MO1450CA Mwave - Mounted Over Range/wo
Maytag MO1450WA Mwave - Mounted Over Range/wo
Maytag MO1650BA Mwave - Mounted Over Range/wo
Maytag MO1650CA Mwave - Mounted Over Range/wo
Maytag MO1650WA Mwave - Mounted Over Range/wo
Magic Chef MOD61AD Mwave - Mounted Over Range/wo
Magic Chef MOD61WH Mwave - Mounted Over Range/wo
Magic Chef MOD62AD Mwave - Mounted Over Range/wo
Magic Chef MOD62WH Mwave - Mounted Over Range/wo
Magic Chef MOD62WOW Mwave - Mounted Over Range/wo
Magic Chef MOD64WOW Mwave - Mounted Over Range/wo
Magic Chef MOD65B Mwave - Mounted Over Range/wo
Magic Chef MOD65WOW Mwave - Mounted Over Range/wo
Whirlpool MODEL_PBK0190
Whirlpool MODEL_PBK0191
Whirlpool MODEL_PBK0838
Magic Chef MODW1A Mwave - Mounted Over Range/wo
Magic Chef MODW1V Mwave - Mounted Over Range/wo
Amana MP1.A Commercial Microwaves
Amana MP1.B Commercial Microwaves
Amana MPD218-02 Mwave - Family Size (60 Hz)
Amana MPD219-02 Mwave - Family Size (60 Hz)
Frigidaire MPF200PBDA Frg(v2) / Gas Range
Frigidaire MPF200PBWA Frg(v1) / Gas Range
Frigidaire MPF300BPDA Gib(v9) / Gas Range
Frigidaire MPF300PBDA Frg(v1) / Gas Range
Frigidaire MPF300PBDB Wwh(v1) / Gas Range
Frigidaire MPF300PBDC Frg(v1) / Gas Range
Frigidaire MPF300PBDD Frg(v1) / Gas Range
Frigidaire MPF300PBDE Frg(v1) / Gas Range
Frigidaire MPF300PBDF Frg(v1) / Gas Range
Frigidaire MPF300PBWA Frg(v2) / Gas Range
Frigidaire MPF300PBWB Wwh(v2) / Gas Range
Frigidaire MPF300PBWC Frg(v2) / Gas Range
Frigidaire MPF300PBWD Frg(v2) / Gas Range
Frigidaire MPF300PBWE Frg(v2) / Gas Range
Frigidaire MPF300PBWF Frg(v2) / Gas Range
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bosch dryer stops, beeps, "Drying" and "End" lights on endyem Dryer Repair 2 10-19-2012 04:46 PM
Maytag Ice Maker - wont "request" water Robotronic Refrigerator & Freezer Repair 1 08-28-2012 10:52 AM
Neptune MD5500 Washer:Error Codes "do" and "FL" with a triple beep and a buzzer sound neptune123 Washer Repair 1 06-12-2011 04:14 PM
Error message "dL" and then "F" shacklem Washer Repair 0 06-28-2010 06:12 PM
oven "moaning" sound then faint "poof" sound; later, large "poof" popped door open samej71 Oven Repair (including Ranges and Cooktops) 2 03-24-2010 07:05 AM
