| » GE Microwave not heating |
Model Number: JKP85WDA2WW Brand: GE Age: More than 10 years
Hi, I have a GE Microwave / Oven combo and the microwave is not heating and the turntable in not running. I can hear the microwave fan coming on and lights are operational. I have replaced the magnetron but still there is no heat and the turntable is not turning. I do remeber that when it was working I could hear a buzzing sound. Any ideas as where to check next?
thanks again Kamran Ads By Google Related Models |
Hi.
You need to know what are you doing to perform the "life" tests on the microwave. First check the primary interlock door switch (top). Check if the primary winding of the high voltage transformer getting 120VAC. If yes - check the high voltage diod and capacitor. Remember to discharge the capacitor before testing it. Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. Last edited by Simon / APP Team : 08-30-2012 at 02:42 PM. |
Hi Simon, thank you so much for replying to my thread soquickly. I have checked the H.V.D by applying 120 vac to it and checked theresult with a voltmeter. It checked okay since it only passed around 60vacthrough it as expected. I think microwave is getting power since the light, fanand control board are coming on! It is a bit difficult to measure thecapacitor voltage since this is a all in one unit and the microwave has 3 setsof plugs underneath it and mounted in a cabinet. If the H.V. capacitor is bad will it stop the turntablefrom turning? Again the symptoms are kind of odd since it is not turning andthere is no heat generating. If the interlock door switch is bad is the symptomabove fits the scenario? Is the switch a mechanical type relay or is it solidstate? |
Hi Simon, I checked all the relay switches and they were allgood. However the top relay looked kind of suspicious, terminal plug lookedlike it was burnt or had some grease or something in it. I cleaned theterminals and scraped them off. Also cleaned and scraped the connectors on therelay as well. Plugged everything back in and guess what now it is working! I believethe door was not making the connection due to the dirty contacts on the relayand the connector. Thanks again for all your help and guidance. I am one happy camper now! Kamran |
I'm glad you where able to fix the problem.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| GE microwave oven combo Microwave not heating | leebee | Microwave Repair | 1 | 08-14-2011 08:17 PM |
| microwave not heating | mtjr | Microwave Repair | 0 | 03-26-2011 03:58 PM |
| Microwave Not Heating | maxroxie1 | Microwave Repair | 1 | 12-06-2010 12:01 PM |
| microwave not heating | Sam123 | Microwave Repair | 0 | 10-04-2008 02:55 PM |
| microwave not heating | Sam123 | Microwave Repair | 0 | 10-04-2008 02:09 PM |
