| » -se- Code |
Model Number: SMH91501B Brand: Samsung Age: 1 - 5 years
When I checked this unit it was unplugged. I plugged it in and it seemed fine. I set the clock and tested it with a cup of water for 2minutes and it boiled. As I worked on the refrig about 10 minutes the -SE- code appeared. I unplugged it a few minutes and retried it and it came back almost immediately. The customer said this happens when she is not using it and even kicked the breaker 2Xs( possible it is on the same circuit as the refrig.
First, what does the -SE- code mean and second, what tests do I need to perform on which parts? Thanks Jamie Pancake Ads By Google Related Models |
Hi.
The SE code means "shorted key". Recommendations are to replace the control panel or smart board. Disconnect the ribbon from the control board, if the SE disappears - replace the control panel. Unfortunately cannot provide the part numbers because the model number you provided doesn't come up. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
You are welcome.
Simon.
__________________
| Display Modes | |
| Duet error code FH and diagnostic code C03 | angelo78 | Washer Repair | 0 | 03-21-2012 08:12 AM |
| F2 code | MeSue515 | Oven Repair (including Ranges and Cooktops) | 0 | 11-26-2011 03:36 PM |
| Code F9 & dr | bwes88 | Oven Repair (including Ranges and Cooktops) | 1 | 01-06-2011 03:53 PM |
| code 33 | ronald871 | Heating, Ventilation, and Air Conditioning (HVAC) | 0 | 02-05-2010 11:27 AM |
| F1 code | albertdiaz | Washer Repair | 1 | 08-27-2008 07:11 PM |
