| » microwave door sensor |
Model Number: kemc377kss Brand: Kitchen Aid Age: 1 - 5 years
When I try and use the microwave it beeps and "door" lights up on the display and it wont come on. What do I need to replace?
Related Models |
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Even though a door switch clicks, it may still be bad inside. Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first. There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door. The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly. Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch. If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using. One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue. You can find helpful exploded view diagrams and order parts by entering your full model number here. There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing. ![]() At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes. If you only need a switch, you can order a universal type here for $5 postpaid.
__________________
William E. Miller † prototech@usa.net |
| Display Modes | |
| oven sensor question/WB21T10007 GE Oven Sensor | lynnmta | Oven Repair (including Ranges and Cooktops) | 0 | 07-18-2009 08:51 AM |
| microwave door error when door is closed | cyounts | Oven Repair (including Ranges and Cooktops) | 2 | 07-10-2009 10:38 AM |
| Will I be able to fix my Microwave door? | acsih | Microwave Repair | 7 | 06-10-2009 07:25 PM |
| Whirlpool microwave door will not open and microwave not working | bbowen | Microwave Repair | 4 | 03-22-2009 04:09 PM |
| Microwave Door | johnebrewer10 | Microwave Repair | 0 | 02-21-2008 01:04 PM |
