| » wmh1164xvs-2 micro doesn't heat up |
Model Number: wmh1164xvs-2 Brand: Whirlpool Age: 1 - 5 years
micro doesn't heat up. I think it the thermal fuse or the magnetron. what do you guys think?
What it does and what it does not besides heating?
Does it make any unusual noise? Here are the breakdown diagrams and Replacement parts for Whirlpool WMH1164XVS2 MICROWAVE OVEN 1.6 CU. FT. | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
The problem can be a bad magnetron thermostat, a bad magnetron or a bad control board. You have to have a simple multimeter to perform some tests. Let us know when you will be ready.
__________________
Gene,
I am having the same problem with my Microwave/Oven combo (MODEL# KEMC377KBS0) and would like to try and determine which component needs replacing. Once i have a multi-meter, will you be able to give me instructions on how to test the components? I'm pretty confident I can replace which ever component is bad - once i figure out which one is faulty. Thanks for any help you can give... |
Hi Bryan,
We definitely can guide you through the troubleshooting process. Let us know when you will be ready. Gene.
__________________
Thanks Gene,
Couple quick questions to get me started. 1) I'm assuming I need the oven to be connect to power before I can test the components, correct? The reason I ask, is because the oven is currently in my garage waiting to be installed in another house. 2) If you were to make an educated guess what the top 3 components that may be bad causing the microwave to run fine but not heat-what would those be? I'm thinking I may go ahead and buy them so i can have them on hand sooner and just return what i don't use. My thinking is go ahead and purchase the Magnatron and the fuse. What else would you suggest i purchase. 3) Do you recommend i get a Digital or Analog Multi meter. thanks |
Quote:
2) So far it is unpredictable. 3) I really don't see any difference. You can find more information in of our previous threads: How To Check Continuity With Ohmmeter Gene.
__________________
Thank Gene,
So i'm ready to start testing. I've accessed the microwave compartment where the Magnetron and other components are located. I've discharged the capacitor (as best as i can tell the capacitor had no energy stored. it's been sitting a few weeks) I have my Digital Multi-meter and have check the fuse (#27 in this diagram) it appears the fuse is fine. What would be the next thing you would check? How do you test the magnetron? |
Hi Bryan,
Attached to this post you will find some instructions as well as the tech sheet with the wring diagrams. You also have to check both fuses, the door switches, the cavity thermostat (TOD) and the magnetron thermostat (TOD). All of them have to be checked for continuity. Here are the breakdown diagrams and Replacement parts for Whirlpool KEMC377KBS0 BUILT-IN OVEN W/MICROWAVE | AppliancePartsPros.com Gene.
__________________
| Display Modes | |
| Micro does heat | pearsonn | Microwave Repair | 1 | 04-24-2012 01:39 PM |
| GE micro runs but no Heat | bmoore196767 | Microwave Repair | 1 | 10-06-2010 08:42 AM |
| GE Micro does not heat | Scojo75 | Microwave Repair | 0 | 09-11-2010 01:48 PM |
| Micro will not heat | msexton63 | Microwave Repair | 0 | 09-18-2009 02:47 PM |
| Micro doesn't heat water | falexander | Microwave Repair | 0 | 10-21-2007 08:12 AM |
